aldo98229
Aldo
Bellingham, WA
2018 Jeep Wrangler Unlimited Sahara, 2018 Fiat 124 Spider Abarth
Market Research
Aren’t the 2021’s also getting cast iron steering knuckles vs the 2018-20 aluminum ones? Sounds like FCA may have gone a little too far trying to save weight on steering components
Perhaps.
IIRC, JL weighs 200 lbs less than JK, despite being larger, having a bigger transmission and more “stuff”. They had to remove the weight somehow.
The new, lighter, Dana axles have been holding together well as far as I can tell. Sure hope they keep doing that.
aldo98229
Aldo
Bellingham, WA
Market Research
Could be that the internals are steel and therefore the difference in the coefficients of thermal expansion between steel and aluminum could have caused looseness in the original assembly. Aluminum expands more with temperature than steels.
I can't tell if my steering is loose or it's just how SFA vehicles are.
Solid front axles have an element of steering play. But having owned 8 prior Wranglers, some of the JLs I test drive felt way too loose.
Redrockjk
JK Wrangler
My 2020 Recon with a build date 6/20 has the new Steering Gear Box, and the steering feel is great.
It would be interesting to see when the new steering gear went onto the assembly line?
-Steven
Did you have the TsB done and the dealer? I can almost promise you it has the old steering gear in it.
ocrejects
Rick
Orange County, CA
2018 JLU Rubicon, 2016 A5 Audi, 2007 A4 convertible
Is this true, the 2021’s also getting cast iron steering knuckles vs the 2018-20 aluminum ones?
ExpeditionBuilds
Rock Sponsor (Level 1)
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Photographer/ Content Creator
No TSB for me. I found the sticker on the Jeep as I was looking under it. It's the new part number.
-Steven
SecondTJ
Il
Jeep
Perhaps.
Where did you see 200 lbs? It looks like less than 100 lbs according to FCA spec sheets.
Still impressive given its physically larger size
ExpeditionBuilds
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Myron
Myron
Mitten State
2020 Wrangler, 1964 Land Rover SIIA 88
I went out and checked my 2020 Sport S. I ordered it May 21 and picked it up July 2, so I was assuming it had a June, 2020 build date. The steering box is the gray aluminum unit, and the sticker was hanging on by a thread. Looks like it's dated June 19, 2020.
entropy
Los Angeles
Jeep Wrangler Sport S JL 2-D
Data Scientist
@Redrockjk I need to clear this up as I Do Not have steering gear #68507569AA on my 2020 Recon.
I have steering gear #68250506AE. This is the AE version.
Attached is a link and pic. https://www.jlwranglerforums.com/forum/threads/new-jl-steering-gear-box-68250506ae.34028/page-2
Sorry to have 'muddied the waters' so to speak!
-Steven
so you have the aluminum steering box?
And youve been saying your steering is spot on. THIS is the case for most jeep owners. I have never, ever, had any steering issues with my 2019
ExpeditionBuilds
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Yes, mine is the aluminum box and the steering is spot on.
I believe the new steel steering gear will be what Jeep is using as the replacement.
Mine's not broke, so leaving it alone...thank goodness!
-Steven
entropy
Los Angeles
Data Scientist
-Steven
Yeah same here. But following this issue just in case something goes wrong along the road.
ExpeditionBuilds
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
How's your steering feel with this part?
-Steven
ATO4x4
