Confirm Fitment of Black Rhino Roku Wheels Please!
Nomoracin
Virginia
JLU Rubicon
I'm about to place an order, but I would like to seek some reassurance that the following will fit please...
wheel: black rhino rokus 17x9.5
offset: -18mm
bolt pattern: 5x127
tires: nitto ridge grappler 315/70/17
I have a 2019 Jeep Wrangler Unlimited Rubicon on stock suspension.
Edit: I shamefully admit that my Jeep will mostly just be a "mall crawler"
Notorious
Kevin
North Texas
2000 TJ Sahara
If you’re going to add 35’s, why not add a lift kit as well as a tazer to correct for the new tires?
Nomoracin
Virginia
JLU Rubicon
I do have plans of lifting it eventually, but I need to spread out the costs...I'm poor. =(
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
offset: -18mm
bolt pattern: 5x127
Should fit fine for street use and mild off road flexing.
Just be sure to reset the programmed tire size. I highly recommend the Tazer light or mini, if the features should happen to tickle your fancy. If not, there are other more cost efficient alternatives.
Notorious
Kevin
North Texas
2000 TJ Sahara
I think we all get it. =)
Once you go 35’s you open up a can of worms to which there is no going back. Just recommending getting it all done in one trip.
As @Headbarcode mentioned, it’s a good idea to recalibrate the speedo via Tazer lite.
Cthehentz
Kev
Vegas
Jeep JLU
I installed a level kit until I could decide what lift kit to go with and availability.. The level kit was just under $100 and took about 2.5hrs to install, that will give you the look of a lift on a budget.
Headbarcode
LI, New York
Since you're not looking to hit the Rubicon trail anytime soon, it'll be fine doing the 35's for now and save up for a quality lift kit and all its necessary peripherals.
Here's a pic of all stock except a set of 315/70-17 BFG KO2's (a smaller 35)
Jeep Wrangler JL Confirm Fitment of Black Rhino Roku Wheels Please! 20190827_132710
Nomoracin
Virginia
JLU Rubicon
Yea, I know that 17x9 -12mm on 315/70/17 works fine...I'm just not sure about 17x9.5 -18mm on the same tires. how does that extra .5 width of the wheels and extra 6mm affect things?
