Concerns with a 4xe, need advice!
SurfScout
Rafael
Carmel IN
2021 Jeep Wrangler Unlimited Rubicon 4xe
Morning All! New here and in the process of making a deal on a 2021 Rubicon 4xe w/aftermarket wheels and lift that's been listed for 4 months. Anything in particular I should look for or test? I've had a drive already and it seems good except for a few issues (not a mechanic), alignment (pulls to the left), brake noise (at very low speeds), oil residue on rear shocks (not sure if it's a leak or road spray), clipped wires under the passenger side doors (possibly from some auxiliary addition that was removed?), open recall ZB7 (very surprised this wasn't handled already). This Jeep is CPO via the listing Dodge/Ram dealership and they agreed to take it down the road to an unaffiliated Jeep dealership to have my concerns checked out plus a general once over PPI of sorts. Just looking for any advice on what to look for with Jeeps in general and the 4xe in particular. Thanks!
SurfScout
Rafael
Carmel IN
Here's a pic of the wires.
Jeep Wrangler JL Concerns with a 4xe, need advice! F8BEFFC8-5087-4AD8-AFB8-6BD1584069DF
SurfScout
Rafael
Carmel IN
Here's a pic of one shock with oil residue.
Jeep Wrangler JL Concerns with a 4xe, need advice! F8190D1F-2C25-41D6-9451-4EE92A8E1509
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
Looks like you've got a good eye. bad shock, for sure. I don' t know what those wires are for - that looks like consumer split-loom rather than something factory, but the color-striped wires aren't often used with add-on accessories - so that needs to be traced to determine what it is. Maybe for lights or power steps or maybe run in through the floor drain plug to the interior.
ZR2to392
Fort Worth, TX
2022 Rubicon 4XE, 2024 Rubicon 392
Double purple wire is for AMP Research powersteps. They use that wiring harness for all their steps. They should route near your ODB port, they likely removed the steps and said to hell with the wiring.
SurfScout
Rafael
Carmel IN
Hi BigMaCro, thanks for the response and information! I think that's a good call regarding the power steps. In the dealer website pictures there are rock rails that actually look like power steps however when I went to test drive it, they were mysteriously missing. Also seems a bit strange for a CPO vehicle that supposedly went through a 125+ point inspection, one or more bad shocks were overlooked but in all fairness, that's not to say they didn't fail after the inspection... Anyway thanks again for the info, I'm learning as I go like most beginners but greatly appreciate this forum and the Jeep community!
sconrad24
PA
2016 Willys JKU, 2021 4XE
If its been sitting for 4 months I'd worry about the 12v battery. I'd factor in replacing that after purchasing. Also those look like the stock rubicon shocks. Did they listed what kind of lift was installed?
SurfScout
Rafael
Carmel IN
Hi ZR2to392, thanks for the detailed info that's good to know! I just messaged the salesman also as I'm sure those aren't cheap. Who knows if they were stolen off or what but I'll definitely use that info for negotiation if the Jeeps checks out otherwise.
SurfScout
Rafael
Carmel IN
Hi sconrad24, thanks for the response and advice! So should I ask the dealership about the 12v battery and if they will replace it or best to do it myself or elsewhere?
They didn't know the brand of lift or everything involved but seemed quite confident it was a 3" lift somehow. I'm skeptical at this point and I agree about the shocks, I was expecting to see something not red after hearing about the lift.
I'll see if I can press them for more info since I know others at the dealership know who traded it in. Thanks!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Do you have any more suspension pics. No way it's 3". Those tags are stock springs and you'd be riding the tops of the shocks without extensions. My guess from what you posted it's stock with some wheels/tires slapped on it.
I assume your getting a killer deal to not look at new?
sconrad24
PA
They probably wont replace the 12v battery if its passing its tests. Theres some good threads here on the forum with better aftermarket options then the factory batteries anyway. Replacing it sooner rather than later could help you avoid some strange behavior from weak batteries.
C.Sco
2023 4xe Rubicon
Don't bother having the dealer replace the battery for you, even if it's bad. They'll just stick in the same kind of garbage OEM battery that it had before. Instead, if the battery is no good then I would have them just discount $200 from the vehicle and then go buy one of the much better batteries recommended on various threads around here. And even if the battery does test good, I'd still replace it anyways; unless the previous owner already did.
SurfScout
Rafael
Carmel IN
Hey GA
Hey GATORB8, thanks for the response and info. I think I have a few more suspension pics, not great ones, but I'll add those and greatly appreciate any insight, cheers!
Jeep Wrangler JL Concerns with a 4xe, need advice! 84F8AA7E-FE84-414F-A0AB-6C73813026D3
Jeep Wrangler JL Concerns with a 4xe, need advice! 86F95F5A-F20D-42E0-8EC0-EC445D01AAB5
Jeep Wrangler JL Concerns with a 4xe, need advice! 5E2A387B-DB68-4359-8FEE-35F988E7A4D3
Jeep Wrangler JL Concerns with a 4xe, need advice! EC441A98-8651-4820-A971-AE4FAE09F50A
GATORB8
CLT NC
Hey GA
Bone stock.
