Spank
Nah, I don't need 37s. In fact, given how high this thing is with 35s, I don't think my Jeep would clear the garage door if I added a couple more inches. My JL actually stands taller than my JKUR did with the same tires and Teraflex's 2.5" lift.So you went with 35s ? i was thinking you were going with 37s. the dealership is telling me they have 4 kits in stock to put on a JL. they say there is no problem with the springs just the way you install them. I know thats not true. This many people are over the USA couldn't all be installing them wrong lol.
That being said, this kit is incredibly easy to install and there aren't a lot of ways to do it wrong unless you're a special kind of stupid. The only hurdle I ran into were the front control arm bolts; those were an absolute bitch to get off, even with a impact driver. Everything else went really smooth and I had fun putting this thing together. It's a great weekend garage project.
No. It doesn't need one. I just want them so I can absolutely center my axles. I didn't even bother with an alignment after I finished installing everything because it drives nice and smooth. I just adjusted the drag link to center the steering wheel.Do you feel like they should have a track bar with the kit ? does it need one ?
Yes, an adjustable trackbar is recommended the higher you go because it'll shift the axle over that much more. However, that doesn't have anything to do with death wobble. Death wobble is more indicative of loose or worn suspension components. As long as everything is installed correctly, you shouldn't run into that issue.someone told me without it will get death wobble bad in time and then someone else said you dont need a track bar unless you go over 3 inches on a lift so i wish i new if it needs a track bar or not
One of the biggest reasons why so many early JKs were getting death wobble was because of the large number of poorly engineered lift kits that had flooded the market. Most of them used a relocation bracket that the stock axle trackbar mounts were not designed to handle. They'd either wallow out holes or snap the bracket off entirely.
Not only are the JL's mounting brackets significantly stronger, most aftermarket companies learned their lessons with the JK and designed trackbar relocation brackets that mount around the entire axle.
