I have accutune/eibach coils on mine, stock pads, and they sit perfectly straight.
With them both bowing towards the front like that it almost looks like your control arms might not be set quite right.
What is your caster number now?put them on, only took me 30 minutes to swap them on my garage floor..im getting good on this.
still bows forward a little bit, used a line laser to check the axle is center, I guess the only way to fix the bow is to dial up the caster(shorten the upper control arm, rotate the axle backward), which will ruin my pinion angle. I had aftermarket drive shaft and those u joints really don't like any angle...
so, I guess I will live with occasional rubbing noise.
went down and double checked it. Since the synergy spring is abit shorter than rockrawler one, I’m getting less lift height.What is your caster number now?
