CO Ketchup Build
mushroomax
Max
2020 JLUR
Calling this the "ketchup" build since I missed the whole JK generation and feel I'm behind the power curve of building a 2020 JLUR that was recently purchased. Browsing thru all the other build threads on this forum has really helped me ketchup with what works and doesn't work for the new JL so a public thank you to all who post in this section. I still own a TJ/60s/40s/coilovers/stretched/LS3/atlas etc that has become more of a trailer queen over the years and in my opinion more obnoxious than not so the direction for this build is to really pull the reigns back and keep it streetable, but add a touch more offroad capability so I ordered a bunch of stuff:
2020 Jeep Wrangler Unlimited Rubicon/2.0T/Non-eTorque
Mods:
Accutune 2.5" Stage 4 Lift, 2.5" Fox shocks w/DCS adjuster
Fox Gen2 IFP 2.0 Series Bump Stops, Front and Rear
Warn Zeon 10-S Platinum Winch
Warn OE Rubicon Winch Plate
37x12.50R17 Cooper STT Pros
Rusty's Hinge Spare Tire Carrier
1.75" Spydertrax wheel spacers to run the stock rims for now
Artec Fully Bellypan Skids - Aluminum
Artec Apex Front Axle Armor Kit, D44
Artec Rear Truss, D44
Artec Rear LCA Skids, weld-on
Dana Spicer 4.88 gears F/R
E-Locker Sensors; potted F/R
Reid Racing Knuckles
Dynatrac HD Balljoints
Doestch Off-road 2in aluminum tie rod/draglink kit
Fox TS steering stabilizer and relocation kit
Borla Climber Touring Cat-back exhaust
RockJock JL Frontend Housing Johnny Joint Kit; RJ-301000-103
Front RCVs w/FAD
Rear Dana Spicer Chromoly Axle Shafts
Adams Driveshaft Rubicon F/R 1350 Extreme Duty Series driveshafts
Nemesis Titan Tub Armor
Nemesis Billy Rockers
Z Automotive Tazer Mini
Cool Tech JL Wrangler Powerport Kit
Weight after build: ~5580lbs
Regearing and beadlocks are in the future but after already running trails like Ironchest and others here in Colorado I knew I needed to get more ground clearance from dragging the jeep over a rock or 12 so now that I have some time this week I'm gonna get the JL up on jacks after work today and start installing the lift.
Jeep Wrangler JL CO Ketchup Build thumbnail_image0
June 2023: Added beadlocks and 38's:
Jeep Wrangler JL CO Ketchup Build Poser_01
mushroomax
mushroomax
Max
2020 JLUR
Managed to get some work done on the front end tonight. Felt like a potato head getting all the control arms lined up and bolted in...but front lowers and uppers are in, bumps are in, both coil springs in and just the passenger side front shock for now. Don’t really like the default mounting location for the front remote reservoirs but for now that’s where they’re going. Wanna knock the lift out quick and get it back on its feet before I start tweaking stuff more to my liking.
Jeep Wrangler JL CO Ketchup Build BA40DD21-59A8-4D1E-8A18-F749476A3721
Jeep Wrangler JL CO Ketchup Build CAB3A490-4FB7-4A44-9789-C74A3E2A6692
Jeep Wrangler JL CO Ketchup Build 7B753973-2BA5-47FA-8373-01AAF9A4375F
Jeep Wrangler JL CO Ketchup Build DA4D99C2-3481-47D4-BD88-7EB86813428F
Jeep Wrangler JL CO Ketchup Build B5208044-E435-44E4-B7A5-9D0FD8B11D88
Jeep Wrangler JL CO Ketchup Build D8DDC62E-D096-4B9F-8837-ADA22F0DA8AE
Jeep Wrangler JL CO Ketchup Build 9FFB6762-0C4E-4F7A-B042-131286293065
Bestop
Peak Sponsor (Level 2)
The Bestop Team
Louisville, CO
2010 JKU
I like the theme and how you have the experience to know what you don't want this to turn into. Builds go so well when there's a direction and intent. I bet the finished product is so clear in your mind, you can't wait to get your Heinz on it.
Lee
- the Bestop team
www.bestop.com
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
mushroomax
mushroomax
Max
2020 JLUR
Lee
- the Bestop team
www.bestop.com
Haha well said Lee. But my mind has already wandered...I caught myself browsing drop-in D60s last night so had to quickly take my Heinz off the computer and walk away.
mushroomax
mushroomax
Max
2020 JLUR
I pretty much got everything wrapped up except the new sway bars links. Spacers came in so I installed the fronts and after looking things over I feel really apprehensive about running em on stock axles. Hopefully the ball joints and everything else will hold up until I go to a more permanent solution.
Jeep Wrangler JL CO Ketchup Build F077F2E5-6B0E-49AF-92F5-9D9A1DD8D611
Jeep Wrangler JL CO Ketchup Build 369363C2-FC0A-4EDA-8AE7-F4854A042938
Jeep Wrangler JL CO Ketchup Build 1FE87C1F-6511-4508-B6AE-6AC11F3EA737
mushroomax
mushroomax
Max
2020 JLUR
37x12.50R17 Cooper STT Pros got mounted and balanced on stock rims today, forgot to weight the stock combo but these weigh 106lbs a corner + whatever the wheel spacers are...I was hoping to be lighter but can’t complain. And the 37 spare hits the rear bumper so I couldn’t mount it on the stock spare tire carrier. Aftermarket one should be here soon, fingers crossed.
Jeep Wrangler JL CO Ketchup Build D5368DBD-FC8C-4AB5-8A91-5DA512B1CAD9
Jeep Wrangler JL CO Ketchup Build 60291370-A29A-467B-8F6D-596D62667592
Jeep Wrangler JL CO Ketchup Build 6D1C9FF9-98C7-40BD-807F-876F4208C061
mushroomax
mushroomax
Max
2020 JLUR
Checked the reservoirs because I was curious what pressure Accutune filled them to and was reminded why I don’t like this mounting location. Maybe I dun goofed but followed the directions to a T. Pressure checks and filling are going to be bothersome in the short-term.
Jeep Wrangler JL CO Ketchup Build 9D16F1BA-2247-4758-9F42-7EC35E663E4C
Jeep Wrangler JL CO Ketchup Build 95A0EE98-43AA-40C1-9A2F-92AC103AE81A
Bestop
The Bestop Team
Louisville, CO
2010 JKU
mushroomax
mushroomax
Max
2020 JLUR
Finally got this bish on the alignment rack, my measurements were almost spot on.
Jeep Wrangler JL CO Ketchup Build E89D41D8-EB35-4427-A542-597E289495D2
Jeep Wrangler JL CO Ketchup Build 20C69140-DBA9-44DA-B021-3928E8A9B67D
Then ordered up some Amazon razzle dazzle to keep dirty hands from destroying the steering wheel. The interior is just too nice compared to what I’m used to...a preemptive strike if you will. It does interfere with the heated steering wheel a bit but I’ll rock it for now.
Jeep Wrangler JL CO Ketchup Build 71F26014-40EC-4806-803A-8B456CA4F407
