OldGuyNewJeep
And if you are, would you prefer limp mode or your pressure plate coming apart?As for off-roading like that, I wouldn't worry about it unless you are for some reason slipping the hell out of it.
I think the font they are using is the same type as the old Route 66 font which can kind of look crooked...So...... anybody with the new flash update notice the 6 is crooked?
Wow. No way to unsee that.So...... anybody with the new flash update notice the 6 is crooked?
While I can see the similarity no other 6 in the whole of the displays use that "style" 6 add that to it being an incredibly useless feature ( that I want gone/never wanted) and on that only makes the cluster more busy....I think the font they are using is the same type as the old Route 66 font which can kind of look crooked...
Or you havenāt seen it because youāve never made it up to that useless gearI think of myself as pretty anal (and my recent thread probably confirms this), but never noticed the 6 being slightly different or maybe never cared enough to look.
6th is only useless if you have 3.45 gears. He has a Rubicon and most likely uses 6th all the time like I do. Being 700 ft. above sea level on the flattest terrain you will ever see helps...Or you havenāt seen it because youāve never made it up to that useless gear
Yep, anytime Iām on the interstate above 65-70. Iām in 6th with the cruise setā¦ The only gear I find useless is reverse, itās geared way to damn high in my opinion.6th is only useless if you have 3.45 gears. He has a Rubicon and most likely uses 6th all the time like I do. Being 700 ft. above sea level on the flattest terrain you will ever see helps...
I find 5 fairly useless. I tend to jump between 4th and 6th.Yep, anytime Iām on the interstate above 65-70. Iām in 6th with the cruise setā¦ The only gear I find useless is reverse, itās geared way to damn high in my opinion.
For this reason I haven't seen it eitherOr you havenāt seen it because youāve never made it up to that useless gear
They canāt paint for and makes rookie mistakes with aluminum. So if the font is incorrect, doesnāt surprise me.While it might seem to be only a minor issue it brings up the question of.... If they can't get a simple font or alignment of a number correct then why should I expect them to get a major issue such as the clutch correct?
As a software developer who often scratches his head over UX (user experience) design decisions, I can assure you itās not a mistake. You may not like the way it looks, but the team responsible does.While it might seem to be only a minor issue it brings up the question of.... If they can't get a simple font or alignment of a number correct then why should I expect them to get a major issue such as the clutch correct?
