DanW
I think you are right, but If there were a sensor, I'd bet it could be programmed to throw a code and trigger a CEL light. Even if not a flashing one.There isn’t going to be a temp triggering a power cut. It’s going to be a permanent power cut reducing risk of slippage and thus reducing temps. Also, flashing CEL is only used for active misfire condition.
But the potential for harm is much greater with an overheating clutch in this case than any misfire. The worst the misfire would do is damage or destroy the engine. That ain't as big a deal as an exploding friction plate/bell housing and subsequent loss of power and a fire, which can hurt or kill someone. It could probably also be programmed to trigger a limp home mode or some other kind of visible and/or audible dash warning.
But it is all moot if there is no sensor, and it appears there is not.
