Clutch Recall (FCA W12 | 20V-124) on 2018-2020 JL Manuals [overheating clutch pressure plate]
Toycrusher
JLUR
I'm pretty sure my pilot bearing is going out at 12k miles. I thought it was a bad rocker arm (known issue with the 12-17 models) because it sounds exactly like a loud hemi tick. However it stops when I press the clutch. I think the dual mass flywheels might be causing the pilot bearings to fail.. who knows. Now I have to find a dealer who can provide a loaner vehicle because the jeep is my daily driver...
I've owned over a dozen vehicles in my life and more than half have been manual trans. I've run a few of those over 150k miles w/o issue so it's not my driving. And at 12k miles?? Definitely some defect.
It doesn't have a pilot bearing. Just fyi
Rodeoflyer
Bert
Conifer, Colorado
so what would be causing the tick with the clutch released?? it's a gear rollover noise, it's loud.. throwout?
Toycrusher
JLUR
so what would be causing the tick with the clutch released?? it's a gear rollover noise, it's loud.. throwout? dont leave me hanging.
Throwout would be a fair guess. Under pressure it may get quiet but noisy without load. Tough to say. This is the only transmission I've come across that didn't use a pilot bearing or bushing
Rodeoflyer
Bert
Conifer, Colorado
Toycrusher
JLUR
Didn't you upgrade to the centerforce clutch? how are you liking it so far?
I love it. I'm sure I'm slower then before, it's slow to rev and rev hang is worse, and fuel economy dropped, but it's fantastic to have the ability to climb a driveway or big curb from a stop without touching the gas pedal. You could actually run up the gears to about 30 in 6th without once touching the gas pedal. No bucking and surging trying to crawl slowly with the clutch out. Just a better, more communicative clutch all the way around.
I did it before the recall was announced and I'm sure I need to change that hose. I'm about to need to bleed it for the third time
Rodeoflyer
Bert
Conifer, Colorado
Additional rotating mass and drive line loss.. yep. I'll take the pluses over the minuses. Hopefully my factory clutch isn't ready to explode.
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Hi, do you happen to have a documented bleeding procedure or?
Thanks!
USAFREODRetired
Colorado Springs, CO
I had to go in to the dealer so they could verify the VIN and maybe verify it was a manual. They had my Jeep for 40 minutes to then tell me they were ordering the part. I told them I gave them all the info so I didn't have to make two 1.5 hour roundtrips. They told me the parts we hard to get (we are talking about an adhesive lined tubing cover after all) and it would probably be about 2 weeks to receive the part.
I called them after two weeks and they told me the part was in and was told they were going to call me that same day. I made the earliest appointment and it took 45 minutes for them to install the sleeve, remove the plastic hose clamp and then bleed the system. I had no issues before the first visit with the clutch or transmission and haven't had any issues since.
I love the Jeep, but there is a reason I have done all my own service.
I've been regularly calling my dealership since the recall was announced. I regularly get email service notices stating I need to address this recall. EVERY time I call the dealership, they just tell me "we don't have the parts." WTF? This recall has dragged on for months, COVID or no they are still rolling Wranglers off the line.
My rig is in right now because of an E-Brake failure, we'll see if they make any moves on the clutch recall, I had them list it on the work order. I suspect it will be the same story.
For one of the largest Jeep Dealerships in the DC area, their service center sucks. They are sooo slooww, like they are all sniffing peanut butter in the back. I had my first couple oil changes done under Jeep Wave, but 2 hours for an oil change and rotation (only 4 of 5 tires every time when I asked for a 5-tire...) I installed a Fumoto valve and do it myself in a few minutes. Unless it's warranty work, won't go to the dealership for service.
Toycrusher
JLUR
Thanks!
I couldn't bleed the dumb thing through the valve on the slave. Centerforce suggested bleeding through the reservoir and that's been working. Put my Mityvac on the reservoir with cap removed, pull 10" vacuum, and pump the clutch like 200 times
Toycrusher
JLUR
Just tested it and actually got to 31 mph without touching the skinny pedal :LOL:
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
I will not go to the dealer for service I can do based on all the various issues that have been reported on the forum. I can buy and change my oil in 30 minutes compared to the 45 minute drive one-way to the dealer. I also installed a Fumoto valve and it works great.
JeepCares
Auburn Hills, MI
JL
If you still need help with the recall, please let us know. They should not be saying there are no parts.
Kaitlin
Jeep Cares
USAFREODRetired
Kaitlin
Jeep Cares
Thanks Kaitlin. Turns out the service department at Koons Jeep is "ethically challenged". Finally got my vehicle back after TWO DAYS for a repair that was all of 1.6 hours of labor, and their claims of "waiting for parts", they knocked out the "Clutch Recall" at the same time (allegedly). The only thing on the invoice was $0.17 for parts for the Clutch.
They ruined this customer's relationship for good. Now I have little to no faith they actually did the repair...
But they were "waiting for parts..." $0.17 worth of parts, that took all of 0.6 hours labor...
InstantAmmo
Washington DC
JL Rubicon
Within 24hrs of posting here @JeepCares reached out to my dealer, and I had an appointment scheduled. A few days later, the recall was repaired - no inspection, no hassle, simply installed the replacement part.
Thank you!
  • Like
Reactions: zyt
