In addition to the increased inertia of our JP6 kits, we wanted to give Jeep owners the option to stick with near stock inertia of our JP5 kits if they desired. Personally I think the heavier option fits the JL better even in stock applications. Interesting to note, I have a customer requesting a customized lightweight option because quickest engine response is what they are looking for for their particular use.Why did you guys chose to keep a light weight flywheel option ? and is the pedal pressure with your system less then Centerforce ?
Resting your foot on the clutch is def a big no no with a MT for sure, especially as light as this one is. I've taught a couple younger guys how to drive our delivery truck and a couple of them did just that. Makes me wonder how many of the failures that caused.This appears to be the most founded opinion I have heard since it appears to be based on more than speculation (as I admittedly have been doing).
Thank you.
Yes. We designed our clutch to work with the stock hydraulics.I would think that a more stock like , inertia would require more slippage and reduce the friction plate life span . And i seems Centerforce had to re design and supply the whole Master /Slave to work with their product . Yet you guys seem to believe the stock setup will be fine with yours .
From memory, individuals who have said they had failures ont his forum have said that they were not resting their foot on the clutch. So we can believe them or not. I personally have no reason not to.Resting your foot on the clutch is def a big no no with a MT for sure, especially as light as this one is. I've taught a couple younger guys how to drive our delivery truck and a couple of them did just that. Makes me wonder how many of the failures that caused.
Agreed but the guys I refered to did so not even realizing they were doing it. One of them even got pissy when I called him on it. Thank you for the insight, your assessments have made more sense than anything I've read to date.From memory, individuals who have said they had failures ont his forum have said that they were not resting their foot on the clutch. So we can believe them or not. I personally have no reason not to.
Congratulations.I got the tracker email today that my Jeep is built and ready to ship, I can't wait to row some gears!
Actually this will be my second in less than a year, my brand new sport altitude was only 4 months old (6K miles) before it was totaled/murdered (long story). I loved the MT even with the 3.45's. Long story #2, insurance came through big time and I was able to order a JLUR. I'm confident the MT will be even better w/ 4.10's.Congratulations.
Despite there being opportunities for Jeep to improve the clutch and gearing, there is still nothing like a Manual Transmission and I love my own JLR. Hope you find the same with yours!
btw It takes a couple thousand miles for the engine and transmission to loosen up and start purring so keep that in mind when you first take delivery.
And what was the result when they did this? Did the clutch on the truck explode, sending shrapnel through the transmission housing, like what has happened with many JL Wranglers?Agreed but the guys I refered to did so not even realizing they were doing it. One of them even got pissy when I called him on it.
Of course not and yes is "should" just wear out the clutch prematurly. This appears to be a multifaceted issue I'm just wondeing if that could be one cause of the initial failure, not the grenading.And what was the result when they did this? Did the clutch on the truck explode, sending shrapnel through the transmission housing, like what has happened with many JL Wranglers?
Agreed, you should not rest your foot on the clutch while driving. But shouldn't the result just be the clutch disc wears out much, much faster?
Regardless, many of those who had the failure were experienced MT drivers.
Love to see a tech geek expose on the JL clutch.In the near future I am hoping to "pull back the curtain" (so to speak) and start a new thread breaking down the attributes of the stock clutch systems to reduce the speculation. Hopefully it won't bore people too much with tech geek stuff.
I'm curious how you know this a multi-faceted issue, since no one knows the cause, and the fine people at Jeep aren't offering one. What do you mean by initial failure? In all the cases the only failure was an exploding clutch.This appears to be a multifaceted issue I'm just wondeing if that could be one cause of the initial failure, not the grenading.
Hope isn't a good strategy. Jeep is too busy trying to quash lawsuits related to their shitty new clutch design.Reguardless, I can't wait untill mine is delivered, hopefully they've quietly fixed things.
