Carpet cleaner.How would you clean it?
I 'spose but it might be a bit difficult getting this into the Jeep much less up to the dash.Carpet cleaner.![]()
Upon deployment, OEM airbag covers are designed to either split, or move out of the way. I'm not sure what the JL's passenger bag is designed to do.If the airbag deploys does the plastic shatter? maybe that is why there now is cloth.
The same way you clean cloth anything? A bristle brush and the appropriate cleaner.How would you clean it?
I can't picture this. Do you got pictures?Is the 2024+ cloth dash good or bad?
I can't picture this, any chance you got a picture of your friend's dash?I have a 2024 Sahara with the black leather and my friend has a 2024 sport with the fabric. I can’t see how it won’t get dirty or stain at some point. No idea why they thought that was a good idea.
You can buy the OEM leather one for about $325 online if you want to replace it. I wouldn’t buy the cheap plastic stick on covers off Amazon or eBay. The passenger airbag is under it. Talk about a projectile coming at your passengers face.
There's plenty of pictures of Wranglers with deployed airbags and their bag cover is designed to split open horizontally.If the airbag deploys does the plastic shatter? maybe that is why there now is cloth.
Honestly, the only reasonable choice is to put four point harnesses all around the vehicle and disable the airbags!Upon deployment, OEM airbag covers are designed to either split, or move out of the way. I'm not sure what the JL's passenger bag is designed to do.
Airbags are highly-engineered, controlled explosions. Putting anything aftermarket on or near the airbag has the potential to reduce your protection, or worse, cause injuries to you.
For maximum safety don't forget the submarine belt...Honestly, the only reasonable choice is to put four point harnesses all around the vehicle and disable the airbags!
I may go to an automotive-wrap place and see if they do bubble-wrap...For maximum safety don't forget the submarine belt...
Oh and the full face helmet and Hans device. It's the only way to be sure.
