Closeout panels
UK-Limey
Ian
Sunny Lincolnshire
2020 JLU Rubicon
As mentioned in many forums posts, the EU-spec closeout panels are GROSS !
I see that lots of people have trimmed them down with a dremmel or craft knife to a much better appearance.
Unfortunately I am not in a position to cut the panels so I was wondering if they could be replaced with the 'smaller' version.
On the drivers side this is removing part # 6QZ89RXFAB and replacing with part # 6KL11RXFAA .
It looks like the holes are in slightly different place but these would be easy to re-drill on the replacement part.
lohr500
Tony
England
JLU Rubicon 2.2 MultiJet Diesel
I just removed the two panels completely without cutting or damaging them. The wiring connectors for the fog lamps are exposed, but they are of a waterproof design and so far after 6 months with the panels removed, the wiring is still working fine. If/when they do fail, they are easy enough to get at to make a repair. I regularly jet wash under the wheel arches and around the fog lamp area so the connections are getting a good soaking with no obvious ill effects.
UK-Limey
UK-Limey
Ian
Sunny Lincolnshire
2020 JLU Rubicon
  • Thread starter
  • Thread Starter
  • #3
Thanks for that feedback. It's reassuring to know that the electrics are able to withstand a battering. I presume that the waterproof-ness (is there such a word ?) of the parking sensors is also OK as they are behind the same panel ? In any case, it's now almost certain that I'll remove them this weekend ...
ATO4x4
