I believe at minimum you will have to get a tazer to program and make it work correctly, as well as you might need to add temp sensors if you want the auto part of temp control to work right. There are threads that talk about it on here somewhere.Anyone here go from a sport s 5 inch radio with knobs on radio to an aftermarket radio and upgrade there stack to keep the knobs? Im considering purchasing the stack with knobs i saw for 150 to retain the knobs but im not sure its plug and play?
Yeah i found a few posts on it. But i have an aftermarket radio installed. So im hoping the stack itself works plug and play. For now i just want the volume knobs back. And to try out the hvac add on in my radio. Maybe down the line add heated seats if the wiring is there.I believe at minimum you will have to get a tazer to program and make it work correctly, as well as you might need to add temp sensors if you want the auto part of temp control to work right. There are threads that talk about it on here somewhere.
