MacBigButt
- Martin
- Jan 25, 2018
- BC, Canada
- Nissan Leaf, 2018 JL Unlimited Sahara
- Vehicle Showcase
- 1
Got out for a good run on some backroads and ended up in a spot where I only had 2 wheels on the ground so a good opportunity to check if my clearance issues in the rear were solved. You can see that the rear left is fully stuffed and there is enough clearance still to get my fingers between the wheel and fender. In the last picture you can see that the left rear is right on the bump stop. The left front is just touching the ground and the right front is close to fully compressed with lots of clearance.
Included a glamour shot just to show off...it is a beautiful day on the west coast.
This is the weird position I ended up in. The Jeep is balanced on the left rear and right front.
Here is the stuffed left rear. Lots of clearance with the Nitto 285/75R17.
This is the left front, you can see the EVO spacer and bump stop. Also a good shot of the King shocks.
The left front
Here is the left rear showing the fully compressed bump stop against the EVO spacer. Just to the right of the "R" in the word "Racing" on the shock.
The left front
