Hello! We aren't experiencing any sort of additional delays, was your order placed directly through us?Awesome, still waiting for my kit to come in, was told another 3-4 weeks
188 lb/in up front, and for the rear 165 lbs/in on the first rate and 230 lbs/in on the second. These are much more capable than your factory springs and you should not experience any sagging with our kits. Once you get somewhere around 400 lbs or more in extra weight, contact us directly as we have solutions available to help with these extra heavy builds as well.@Clayton Off Road
On your 2 Door 2" lift, What will the Spring rate be? I haul a fridge and gear in the back along with towing a Teardrop camper. My factory springs sag almost 2" when loaded.
Thanks for the fast response. I shouldn't be exceeding that load. Will these be 2" front and rear, or will they remove the negative rake the two doors "appear" to have? Like 2" rear and 1" front.188 lb/in up front, and for the rear 165 lbs/in on the first rate and 230 lbs/in on the second. These are much more capable than your factory springs and you should not experience any sagging with our kits. Once you get somewhere around 400 lbs or more in extra weight, contact us directly as we have solutions available to help with these extra heavy builds as well.
It's our 2.5" kit which will give you about 1/2" of positive rake!Thanks for the fast response. I shouldn't be exceeding that load. Will these be 2" front and rear, or will they remove the negative rake the two doors "appear" to have? Like 2" rear and 1" front.
I ordered a month ago via one of your resellers/installers. I heard yesterday lower control arms availability is the holdup.Hello! We aren't experiencing any sort of additional delays, was your order placed directly through us?
I'd be happy to look into this a little bit further for you, at the moment there are no additional hold-ups that I am aware of, all kits are shipping out 3 - 4 weeks after the order is placed. If you have an order number or any other information that would help me look up your info, feel free to PM me, and I would be happy to look into this for you!I ordered a month ago via one of your resellers/installers. I heard yesterday lower control arms availability is the holdup.
I ordered on 2/14 and got the kit on 3/8 so about 2-3 weeks.How well does this lift pair with the falcon shocks? Also what is your lead time. Called and emailed you guys but no response.
That's not bad at all thanks for the info!I ordered on 2/14 and got the kit on 3/8 so about 2-3 weeks.
Looks great! Can't wait to install mine. Are those Rubicon fender flares I see?2.5 Overland kit with Fox Shocks went on yesterday!!!
Yes sir they are!!!Looks great! Can't wait to install mine. Are those Rubicon fender flares I see?
What tire 285/75 R17?2.5 Overland kit with Fox Shocks went on yesterday!!!
