Not normal. Sounds like you blew a fuse or didn't use the fuse tap properly. Did you use an add-a-fuse/fuse-tap connector? If so, does it have the 2 fuses properly seated?I have the Oracle oculus headlights and wires the halos up to the cigar lighter fuse. The halos work but the cigar lighter doesn’t work anymore, is this normal?
Because there is no DRL fuse. The Oculus headlight instructions, as well as other after-market headlights with DRLs, say to use a switched ignition source for DRLs. That source is typically the cigar lighter fuse (F52) or one of the heated seat fuses (F57/F58).Why did you use the cigar lighter fuse and not the DRL fuse?
No need. As stated above, the Oculus headlight instructions, as well as other after-market headlights with DRLs, say to use a switched ignition source for DRLs. That source is typically the cigar lighter fuse (F52) or one of the heated seat fuses (F57/F58).I would find a different fuse to tap off of.
Yea that's my fault, I guess I just associated that fuse with DRLs for whatever reason. I disabled my DRLs and unplugged the halo wire, I wasn't a fan of the look like my kids are.No need. As stated above, the Oculus headlight instructions, as well as other after-market headlights with DRLs, say to use a switched ignition source for DRLs. That source is typically the cigar lighter fuse (F52) or one of the heated seat fuses (F57/F58).
Can also use F45 (Rear Cargo - IGN)I have the Oracle oculus headlights and wires the halos up to the cigar lighter fuse. The halos work but the cigar lighter doesn’t work anymore, is this normal?
You always need both fuses for a fuse tap/add-a-fuse to work.I fixed it. The instructions said that the fuse that shipped in the connector was "spare" I took that to mean don't need it. Turns out that having both the "spare" and the original cigar lighter fuse makes it work.
