Chocolate Thunder’s Most Excellent Build Thread!
RockyMtJL
2019 JL Rubicon Unlimited
nice! What made you go with these over the MC ones?
1/23/2021 27,812 miles
I got Rock Krawler No Limits front sway bar links in a few days ago and had the chance to install them today. It’s a straightforward swap of parts to replace the SteerSmarts links.
Chocolate Thunder
Chocolate Thunder
Jeremy
The MC ones are just exactly like stock ones only slightly longer. These are longer, length adjustable, and have helm joints to allow a lot more articulation.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Nice man! You're going to like those! #Beefcake
Chocolate Thunder
Chocolate Thunder
Jeremy
2/25/2021 29,443 mikes
I went out to see @rustyshakelford at BnL Jeep Shop to pick up a new MetalCloak front driveshaft and have him install it. Simple easy swap. Looks good. Now I won’t rub anything in front when fully flexed and won’t damage the shaft from the extreme angle at the transfer case end because this one’s got a double cardan joint.
Chocolate Thunder
Chocolate Thunder
Jeremy
2/26/2021 29,545 miles
I put the SkidRow Offroad curly exhaust skid plate on. Gathering tools and taking pictures both literally took longer than installing it. There’s only 2 bolts, so it took all of 3 minutes to install. Will it help? Maybe. Certainly it’ll protect it from light hits and scrapes. My only concern is that there’s not clearance between the exhaust and the skid so I’ll have to see if it causes any vibration or abrasion on the exhaust shield on that part of the pipe. If so I can place a washer or two under the upper control arm nut where it mounts.
Chocolate Thunder
Chocolate Thunder
Jeremy
Yeah, in this pic it looks like it might just give you some rattling. Can you beat that small section of the exhaust guard in a bit?
It might work out better if I just cut the aluminum heat shield off altogether.
EDIT: cutting the shield off seems like it’d be a PITA, it’s got a couple of spot welds. SkidRow should make the shield just 3/8” wider, it would fit without exhaust interference and there’s plenty of room there, it wouldn’t be in the way of anything else.
Pressuregarage
Kaimana
Kauai,Hawaii
2019 JL Sahara
Operating Engineer Local 3
10/12/2919 13,893 miles
I had a chance to get a little work done today in magnificent weather. I started installing my ARB twin compressor under the passenger seat using the Innovative JK bracket. Other than a few hiccups from working in tight spaces with big hands it was pretty straightforward. Got the wife to actually help me in a useful way getting her smaller hands under the seat track. Got it mounted and all of the plumbing put in. Next up is wiring it up to power.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 509A3762-CE76-453D-9C88-B6BB306077D9
I like this option. How’s the noise when airing up. It’s pretty loud I’d imagine
Chocolate Thunder
Chocolate Thunder
Jeremy
Not really loud. You hear it humming. It’s not quiet. You feel it vibrating in the passenger seat. But I wouldn’t call it loud.
Chocolate Thunder
Chocolate Thunder
Jeremy
I had a few minutes to try to correct the interference of the SkidRow exhaust skid. I wheeled it hard once and it barely contacted the shield on the piping. The small spot.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 8B0039B0-A014-49B1-9D07-E79F9057A836
Washers.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 09B643C6-15FD-41C4-B3F2-2BD5CA368E21
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 3CB7209A-C517-4389-BC9A-666C4C35FCBD
Nut thread engagement.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 73F84491-FADF-4E29-BB87-1B4AE127CC97
Space between exhaust shielding and skid.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 845B4400-C2CA-4944-9E18-3FF4646F5CA6
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 67A99A96-2257-48E7-B06F-EDE98F7CE108
Chocolate Thunder
Chocolate Thunder
Jeremy
My wheels are +12 offset (5.22” backspacing) and I have the MetalCloak 2.5” lift which recommends 4.5” backspacing or less. I installed a pair of Synergy 1.75” spacers which puts it at 3.47” backspacing which is great as far as suspension clearance, but it’s too much wheel poke for my liking.
So I ordered a set of1” Bora wheel spacers which arrived today. That’ll put the backspacing at 4.22” and bring in the wheels .75” at each corner. They look and feel like quality parts. Time will tell. I’ll get them on later today I hope if the rain holds off for a while.
lembowski
San Diego
2018 JLUR Sting Gray
I haven’t really examined it and decided how I’m going to wire it. I think maybe underneath the rocker panel trim, under the glove box, and through the firewall somewhere. I’ll waterproof any opening through a grommet by using some silicone.
Did you end up going through the passenger side firewall grommet or elsewhere? I have my kit coming soon and want to start planning it out.
Chocolate Thunder
Chocolate Thunder
Jeremy
Chocolate Thunder
Chocolate Thunder
Jeremy
Yes, but I had a local Jeep shop do the electrical wiring. It wasn’t expensive, it was done right, and I didn’t have to do it.
Chocolate Thunder
Chocolate Thunder
Jeremy
I got my Armorlite floor in this week. I’m still waiting on delivery of several cans of Boom Mat spray on sound deadening. So I removed the carpet which is very easy. Once it arrives I’ll give the floor pan and lower firewall a coat or two before installing the floor covering.
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 389CB983-DBCF-47EC-BA7C-A4722FF34173
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! A0E13B6A-2DE6-402E-B228-1D6269E03C33
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! F7CE2913-406A-496E-9EDA-2DBF1695778A
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 53A0E8FC-0C3A-4DE5-A3B7-B4EA818FE481
Jeep Wrangler JL Chocolate Thunder’s Most Excellent Build Thread! 366D5BCF-1358-41C0-AB63-E987616DAE97
Naturally I expected to find a little trash and a few surprises under the seats. All of it was under the front passenger seat. Most of this was not unusual. But who recognizes that little guy on the right? That was a surprise.
