Cheap Jeep Hacks! Show 'Em Off Here!
sgtmajor138
Jack
South Central Kentucky
2020 Wrangler Sport S Freedom package
Cheap non-homelink or homelink-like hidden garage door opener hack.
Rather than having a loose door opener in the cab, I used velcro to stick it behind the heat, A/C etc controls. Then added a momentary button in the cubby below.
Only took about 15 minutes and a few cents for the switch.
Would you please elaborate a little more on this? Specific switch you used, how did you wire up the switch, any more helpful tips, etc.
Thanks!
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Thanks!
I had to open up the garage door remote (same way to change the battery) and solder a wire to each side of the momentary switch on the circuit board. Recommend using a meter to verify the right contact points. My remote's circuit board had a DPST momentary switch so I had to make sure I had the right two solder points.
Then cut a small notch to pass the wires through the plastic remote cover.
Then soldered a switch on the other end of the wires like this one pictured
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! PTT-SWITCH-L-DSC03556
Just like these listed on Amazon - https://www.amazon.com/dp/B07XXLHLT...abc_1QW3Z062BHT18MNKQFM9?_encoding=UTF8&psc=1
I basically added a remote wired momentary switch to the garage door remote.
americonium
Abe
NY
2018 JLUR Black
Engineering Technician
You might want to add an ignition controlled relay on the cold side to keep anyone from opening your garage door when the doors are off.
Htfan
Orange County, CA
That's a good addition to make it more like homelink. And may be necessary if you park outside with a soft top, topless or doorless. I considered that also but didn't have any relays laying around.
My JLU is parked in the garage so not necessary in my case.
I'm guessing 80% of the garage door remote using population have the same problem with garage remotes on the visor (or somewhere else in the cab).
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
I just put my opener in the key holder slot between the cupholders. Fits like it belongs there, no one ever notices it.
Htfan
Orange County, CA
That's a nice spot, my wife puts her phone there.
The Last Cowboy
San Antonio, TX
Wandering Vaquero
My phone rides between the parking brake lever and the console. There’s a little rubber pad there for it to rest on. As for hers, I plan to get one of those little trays that fit between the grab handle and the dashboard.
WilhelmSR
Wilhelm
Maryland
2021 HellaYella JLUR
Designed and made this mount for my Tazer yesterday. My material cost was around $0.40. Made from ABS
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! 1615738808293
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! 1615738823065
Multiple places..
@The Last Cowboy
You're a Cowboy.. your Cowgirl may find leather... Yee haa.... more appealing versus Chinese plastic... 8-)
Forum Sponsor, Gibson Leather Works, sells a terrific, easy to install holster for the smartphone..
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! Holster01
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! Holster02
BackToWrangler
Levittown, NY
2021 80th Anniversary JLU
Well, one of my little mods / hacks, is the plastic hook I installed on the inside of my JL's fuel door.
Thanks to the hook, no more gas cap lying on the painted surface.
Also, keeps the gas cap out of mud, snow or sleet on the side of the JL.
I have had the hook installed or months now and geeeeeeeeeeeeeez, it has worked out well.
It's just one of these trimmed down and applied to the fuel door:
You can read more about the hook and where to get it, here:
https://www.jlwranglerforums.com/forum/threads/jl-fuel-door-install-video.4861/page-2#post-298930
Very smart! Thanks for the tip!
elf883
steven
NY
2019 JlU
stationary engineer
better yet i dont have a garage so dont need one lololol
but @Htfan, bravo nice little hack ill use if i ever get a garage lolol
Htfan
Orange County, CA
Appreciate the shoutout @elf883! Hoping you get your garage one day!
Also, been using the cheap hack for over a week now and can confirm its working well as planned
oldmannewjeep
Malcolm
Dallas, TX
2020 JLU
@The Last Cowboy
Seconded. Have the key fob too; they do great work!
Volstock
Bob
Tennessee
2021 Jeep Wrangler Sport Altitude
Info Sec
Installed one today. Picked up a bag of clips from Amazon so if you are in the Nashville area and need one I have plenty left over.
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! PXL_20210323_155629527
Jeep Wrangler JL Cheap Jeep Hacks! Show 'Em Off Here! PXL_20210323_155416422
NCIC105
Upstate SC
2018 Rubicon
The company also sells a solid tubing. Does anyone have any experience with using it.
The reason I ask is that the gap between the fenders and the body is not consistent along the seam. I worked hard to get the welting evenly placed. But, the pressure washer drives the hollow welting inward in some places and not in others. Wondering if the solid stuff would work better. Either way, I love it out here in the land of decomposed granite particles ... does it's job well.
I use it. Every now and again I have to push it back in.
