Cheap Jeep Hacks! Show 'Em Off Here!
MandKM
‘73 CJ5, ‘19 2-door JL Rubicon
Did this work?
Well, being from SoCal, I haven’t had the opportunity to check it out. However, I will be heading north this weekend and rain is expected.
I’ll let you know what I find out.
MandKM
Did this work?
I checked it out this weekend. It did pretty well in a light rain. It diverted most of the water to the ends of the seal at the hinges, with just a few water drops forming near the center. However, I’m not sure it will be able to handle a heavy rain. In that case a more pronounced seal may be needed to direct water to the edges.
Aidencaster
Anto
Alberta
2018 Jeep Wrangler JLU sport
2 small army box with steel angles mounted on the hardtop bolts.
Extra storage for slings at 40$.
I cut the handles and I plan to use handle loop to hold a flashlight.
Hey so I've been looking around. Where did you pick up the brackets you used for your munitions cans. I am trying to do something of the same thing.
dajaga
Canada
2019 Wrangler JLU Sport
Rhinebeck01
2018 2dr. Rubi
I'm not sure if I have ever posted this hack, but will mention it now.
Take a piece of foam pipe insulation, cut it the proper length and squeeze it into the space between the front seat (drivers side and passenger side) and the center console.
I used black, pipe insulation that has an outside diameter of 1.5 inches. I used an 11 inch long piece alongside side of both drivers seat and passenger seat.
Do this and no more dropping, charge cards, change, keys or whatver and having them drop down to no man's land so to speak. You drop something and there it will be sitting on top of that foam pipe insulation, waiting for you to retrieve it,
Yes, the seat(s) will move freely just as they always did.... has no negative impact on the JL. You don't even know it's there til you drop something.
Public Service message: IF you ever drop a credit card, driver's license, etc. in the gaps around the parking brake handle, do not try to pop the cover that surrounds the lever. You will do very costly damage doing this. Better to easily loosen the console and retrieve the item wihout doing costly damage. Come to the forum and ask how to loosen...
Rhinebeck01
2018 2dr. Rubi
This hack can save you money or at least a lot of aggravation...
Regarding the JL being "water resistant" and such.... :facepalm:
Years ago with one of my JK's, I was out in the mud and got back in the Jeep and got mud all up into the OBDll port. What a mess to deal with. It's just so easy to splash / get mud into it if you tend to get out in the yuck and then jump back in and...
Anyway, since then I buy and place a General Motors, OBDll cover over the OBDll port. Yes, it fits the JL's OBDll port perfectly.
I take a 6" piece of fishing line and tie one end to the cap and the other end up above and slightly behind the OBDll port itself to a cable there. I do this so when I or a Tech remove the cap that it just dangles there until I or they put it back on the OBDll port. Thus it does not get lost.
With the cap, the OBDll port is protected.... from snow, mud, water, horse shit, etc., that might head up the OBDll ports way.
For $10.00+- , the cap is a good investment. I know getting the mud issue in the OBDll port, remedied, years ago cost me way way more the that.
Real cool custom OBDll cover with JL grill on it..
https://www.etsy.com/listing/844123...wgrille-black-or?ref=shop_home_active_3&frs=1
Picture cap of below. Can be found on eBAY, etc..
Plastic Cover for OBDll Diagnostic Connector GM12146933
Rhinebeck01
2018 2dr. Rubi
Future hack ...... I'm looking forward to.....
Anyway, I think I found something I have been seeking out, since I got my JL ..
Caps to cover the key hole on a JL ...
What a great addition to the JL..
Especially, for someone anal about the "look" or worried about the mud, water, yuk, getting into the door locks... and water getting in the door locks and their freezing up and and... Been there done that... 8-(
Anyway, custom made , quality caps for the door key hole, that fit so tight that you really need no adhesive to hold them on.. I'd use adhesive any way, just to be sure they don't go awol lets say...
I'm getting the caps with no key hole as I have Proximity but there is a version of this cap with the hole for a key to pass thru...
I'm going to be installing the caps I am talking about in the next week or so ..SO, don't go to eBAY and spend $25.99+ (YIKES) for a somewhat similar set of caps that do not fit snugly and need adhesive to stay on.
Wait til I try the ones I mention... These sell for very very little money. Well worth the $.
Hopefully , this find works out for me.. if not, either way I will post and let those that want a set know either way. My hopes are up....
Would look like this ... matches very close to door handle color. Looks factory...
DanW
DanW
Indiana
Those are great! Linky?
BernJLUR
Bern
Bradenton FL
2019 Ocean Blue JLUR (on order), 2015 Anvil JKU, 1995 4.0L YJ
And french fries!!!
Rhinebeck01
2018 2dr. Rubi
@DanW
I'm hesitant to give out a link to them just yet. I want to try and then post here if they are any good... how fit is and such. I will post and give feedback as soon as I install toward the end of next week.. By the way, these are Made in the USA...
I was just showering and thinking... excited about getting these... really.. Doesn't take much to excite a 71 yo... 8-)
I started thinking, no more having to place tape over my door locks in the Winter so they do not get water in them and freeze up..
No more putting tape on the door locks when I go to the Quarter car wash to rinse off the salt in the Winter... the pressure spray forces the little door open on the key locks...
Also no more worrying about forcing mud into the key locks when I rinse off/ p. wash, after being out in the mud, off road etc...
No more salt and sand blown into the locks at the beach...
For years, I have been frucking around with black tape on car/truckdoor locks..... looks like no more doing that in regard to the Wrangler JL.
Anyway, will let you @DanW know next week how they work out. I know they are inexpensive and do expect them to be well worth the $. Will even improve the looks of the JL.. Cheap insurance so to speak...
JW-UK
Jason
England
D110, Foers Ibex
Hi All,
This isn't a Jeep or JL specific hack, it will work for anyone that has a 1" Ram Mount and a Mini Maglite. The torch, 18mm body diameter, will clamp directly in the Ram Mount arm, without any special adapter.
It works best with the spring end of the arm on the ball, so it grips the torch until the clamp is tight. It is easy to adjust with one hand after a few tries.
I've got a new torch in black since this picture was taken.
Hope you find it useful!
DanW
DanW
Indiana
Hi All,
That is a great hack! Thanks!
Rhinebeck01
2018 2dr. Rubi
OK, here is the link to go to, to purchase the Door lock, "Snap Caps" custom fit, door lock covers, that I have been talking about.... Get them while the gettin's good. 8-)
https://www.etsy.com/listing/838362130/jeep-wrangler-jlgladiator-jt-door-lock
Morris 4x4 Center
