Woolf
My 2020 wrangler unlimited rubicon started giving me a warning today concerning the charging system. The icons on the dashes were a red battery on the left and start/stop malfunction on the right. I realize that the start/stop system will not work if the battery is low. The voltage started off in the 13 volt range after it happened, then after I turned it off and was driving around town it would stay in the 12-low 13 range. The message I received was “Your vehicle's Charging System Warning Light recently indicated there may be a problem with the electrical charging system. Have your vehicle serviced at your dealership immediately.” So far I have not had any issues with starting the engine which leads me to believe that the auxiliary battery is fine and that the issue might be the main battery or alternator. Am I right with this assumption and has anyone else experienced this issue?
