Changing oil without opening the filter
Guv
2018 Wrangler Sport 2.0 E-Torque 2 Door
I don’t believe this is a real question people. No one could be this messed up.
mil-spec gear
Louis
Wisconsin
Jeep Grand Cherokee, Saturn Sky, Jaguar F-type, Silverado Pickup
If you open just the oil cap and let the oil drain without opening the filter, is it not good enough, even if you let it drain overnight? I'm asking this because every time I change my oil so early, my filter is so clean, so I don't want to change my filter.
3.6 pentastar, thank you
First of all, don't go by the way the filter looks. It is just straight up unwise to not replace the filter when you replace the oil. Secondly, if you are worried about the housing cracking replace the OEM housing with an upgraded aluminum housing. There have been too many complaints about the polymer housing cracking and warping in the 3.6 Pentastar to ignore, whether it be from over-tightening, or degradation over time due to heat exposure yet Jeep claims that the notorious Pentastar oil leak problem has more to do with the O-rings failing than an inferior housing. Also, use a good full synthetic oil like Mobile One or Amsoil that are rated for 20,000+ miles along with a Purolator or WIX oil filter that lasts the same. This way you don't have to change your oil at 2000 miles and instead change it at about 10,000 miles to ensure that your engine oil is always good and doing its job. Also, buy an aluminum cap for the oil filter housing and ALWAYS use a torque wrench to tighten the cap at the recommended torque settings.
flyer92
Nevada
I share your concern about the fragile oil cooler housing, but you can still replace the filter like normal and tighten the cap with a (calibrated) torque wrench to the 18 lb-ft spec. That way, you'll know exactly how tight it is and ensure that you don't crack the housing. TBH, you can actually tighten it below spec for added peace of mind. I typically do 15 or 16 lb-ft, and it works just fine. Hope this helps and happy Jeepin'!
jellis4148
Missouri
Or here is a crazy thought. Stop making all these threads asking the dumbest questions. Do you just sit around thinking this crap up? I honestly can see why you have been banned from other groups and forums.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
Maybe stop changing your oil every 1000 miles
Eyeball
1997 TJ & 2023 JLUR
Jeep Junkie is the first and only person I have ever blocked on a forum. Too bad it only blocks what he writes and not his posts entirely. He is a troll and the community just keeps taking the bait.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Yeah but I do not want to open that filter housing too much
Don't let that plastic filter housing scare you my friend. Let me explain it so you can understand it. You have to be gentle with it. Make sure the threads are clean, oil the O-ring real good like. Just snug it down. Do not over tighten it. Remember, just snug. Use a very small wrench or ratchet handle. Don't go using a 2 foot breaker bar. You gotta take the time to rub an old dog behind the ears first, be gentle.
Jeep Wrangler JL Changing oil without opening the filter {filename}
I would recommend against using one of the current aftermarket aluminum oil filter housings, unless they recently incorporated the separated oil and coolant port seals between the cooler and housing.
Jeep Wrangler JL Changing oil without opening the filter 20240305_035357 (1) (1)
Jeep Wrangler JL Changing oil without opening the filter 20240301_155435
Jeep Wrangler JL Changing oil without opening the filter 20240301_155452
Jeep Wrangler JL Changing oil without opening the filter 1000003099 (1)
jadmt
jeff
montana
he is one of three for me and every once and a while I unblock him and soon realize why I blocked him in the first place...the other two ended up being banned so I no longer have to worry about them..funny thing they all lived in the same general area lol...maybe they are all the same person...lol
A 2K oil change? No, No, No and you wont buy a filter? You are throwing money out the window. If you are running synthetic, you can run much longer without issue. I make it a point to change early at "5000! miles" filter and oil.
Jeep Wrangler JL Changing oil without opening the filter depends
... on your utilization. Some driving types are more severe on the oil than others.
