Changing oil rear end.
JustDave
Kersey
2021 Jeep Wrangler
I had my rear end regeared. Should I change the gear oil at some point, & if so, what do I use? Conventional or synthetic?
BDinTX
Dallas, Tx
Rhinebeck01
2018 2dr. Rubi
@JustDave
Do read all the pages at the link that was given to you in the last reply..
YES, you do want to change the gear oil out and don't wait a long time to do so... You will want to drain and carefully look over the drainage and what is in it /might be found on the magnetic drain plug...
You will get different answers when best to do this first drain and check.... some will say 2,000 miles others will say less....
DO use Synthetic. What to use fluid wise... hints on doing the deed, etc., can be found at the thread mentioned.. Remember, always be sure you can get fill plug loose BEFORE you drain the fluid..
Motor City Aftermarket
