Centerforce II or Dual Friction Clutch- Help me decide
HeavyUser
CO
JL
  • Thread starter
  • Banned
  • #1
Hey guys, my dealer agreed to do a free clutch install while my JLR is in for warranty work for a Rear Main Seal leak. I'm having a hard time deciding between the two available Centerforce Clutches. I have 37" Tires and Stock Rubicon Gearing with no intentions of regearing, the vehicle's primary use it offroading.
Is the Dual Friction overkill, should I stick with the Centerforce II?
Any advice would be appreciated.
*Edited
vavaroutsos
Pete
Scotts Valley, CA
Is the Dual Clutch overkill, should I stick with the Centerforce II?
Maybe links or model numbers for the clutches you are considering would help. I did not see any dual clutches from Centerforce for the JL, only two models with different friction materials. The "Dual Friction" model uses two different friction materials on each side of the clutch disc, one for holding power and the other for control.
Amaruq
Atlanta
JLR 6spd
Yea I think he’s referring to the Dual Friction model vs the centerforce II.
HeavyUser
CO
JL
  • Thread starter
  • Banned
  • #4
Yup, adjusting post and thread title!
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Watching for the same input.
Gregj
fdFifty
Pittsburgh
2022 Jeep Wrangler Rubicon
I sent centerforce an email about this. From what they told me, both will have very similar driving characteristics. However, the dual friction gives you a step up in holding power.
From what I can see, both options have more than enough holding force for a stock 3.6.
They both come in at a very similar price point and it doesn’t look like there are any trade offs by going with the dual friction. I guess it really comes down to whether you plan on adding more power down the road. (E.g. supercharger or turbo)
For me, availability is going to be the deciding factor between the two.
Amaruq
Atlanta
JLR 6spd
Interesting. Still curious if this holding power is translated best off-road. It’s heavier, yes? Does this dual friction negatively affect gas mileage more than the regular centerforce? Does the regular centerforce not affect gas mileage?
they completely skipped over these questions when I emailed them. Thanks for your reply.
HeavyUser
CO
JL
  • Thread starter
  • Banned
  • #9
I'm assuming more holding power will also benefit my 37s?
Thanks for the replies so far.
fdFifty
Pittsburgh
I think they both come with the same heavy flywheel. Could be wrong though. There are some posts in other threads about gas mileage people are seeing with this setup. From what I read last, seems like mpg is about the same. Maybe a little less but not significant. I think a lot depends on the type of driving your doing. A lot of stop and go could take a bit more energy to get the heavier flywheel moving, but you could see an improvement while cruising because of the increased inertia.
This is what I was really curious about because I’m going to be towing a small boat trailer. I mentioned this to centerforce and it didn’t seem like they recommended the dual friction over the centerforce II specifically for towing but I definitely could be wrong.
If the centerforce II can hold 434 ft/lbs of torque, but the 3.6 only produces 260 ft/lbs at peak, wouldn’t any force above 260 just overcome the engine or other parts first?
