WranglerMan
- Will
- May 8, 2018
- Katy Texas
- 2018 Wrangler JLU Sahara
- Occupation
- Gas Pipeliner
- Vehicle Showcase
- 1
Ok this is a first for me, not sure how other JL’s are equipped but I have a USB powered port inside my center console that I use to plug my phone into and use car play well on the way home this early morning I plugged my phone in and nothing, at first I thought ok bad cord but upon closer inspection the port had no power indicated by no LED ring around it like the others but the one up front as well as the one on the back side of the console on the outside worked ????? So I am thinking a fuse but the others worked so I looked to see what fuses power these and I believe they are 15amps and labeled F102 and F11 and both metered good so I put them both in and upon restart all was good so first are these the right fuses from those more experienced and if so what caused it to go out but then come back on ???
My JL seems like an old house that always commands my attention with the quirky little things that happen
