sardogtella
- Jim
- Nov 23, 2021
- Burlingame ca
- 2012 JKUR. 2021 JLURXR
I just mounted a two meter ham radio I need for SAR. Mounted the detachable face plate on the dash using the Bulletpoint system. The main unit is located beneath the passenger seat. Ran the wires inside the the door sill and up through the dash. The reinforced tire carrier which comes with the XR package has an antennae mount on it so that was a slam dunk. Also installing the Cobra 75. Plant to mount the small control unit under the seat next to the ham and manually switch out the antennae when using the CB. Grounding didn't cross my mind and I will need to grind off some powder coating from the tire carrier to hopefully get a decent ground.
