AK0311
- John
- May 30, 2018
- Anchorage, AK
- Me: 17 Renegade, Wife: 12 Journey, Kids: 09 Avenger Want: JLUR
- Occupation
- Retired
2M is Ham Operator slang for the 2 meter band (144-148 MHz). CB is technically the 11 meter band at around 27 MHz. The band refers to how long the radio wavelength is. This is why CB radios are 48-102" on average, but 2 meter antennas are less than 3 on a mobile setup. the 70 CM band is even shorter. I have a dual band antenna for my truck that's 19" tall for use on either 2M or 70CM bands. There are also 1.25 meter and HF mobile radios.
I have a Kenwood 2 meter rig that pushes either 25 watts or 65 watts (high or low setting). All CB is only legally allowed to use is 4 watts. The issue with getting and using ham radio equipment is A. it all requires a license, B. it's also dependant on who in the area has a license AND a radio AND is on your frequency.
With CB you are limited to 40 channels (120 if using a SSB radio). All you have to do is turn the knob and it only goes through those frequencies for each channel. With ham radio, you can tune in any frequency on the band with most mobile radios. So you can spend considerably longer times looking for someone to talk to unless you have a predetermined frequency.
Like others have said, the antenna length is determined by the frequencies you want to use. I'd recommend using a short (3-4') for road use and a long 102" whip for off road to maximize your distance. Most bases you can simply unscrew the vertical portion in under 30 seconds.
Also, you mention 36 mile range walkie talkies. I would bet money you will never see 36 miles in actual real world talk distance with those. The antennas are extremely inefficient, the transmit power is less than a CB and the frequencies are susceptible to interference from objects between the two radios like trees and buildings. I have several of those from Uniden that I'm lucky to get 5 miles with vehicle to vehicle on open road. The vehicle body itself blocks the radio waves (metal cages with windows). Unless you have some that you can run an external antenna, you probably are lucky to get 5-10 miles at most. With my 5 watt 2m/70cm handie talkie, I can hit the repeater 8 miles from my house. I've turned the power on it down to 1.5 watts and still hit that repeater.
