Most people here are using adjustable LCAs so it may take a while for someone to chime in with any experience with those.Beuller.......beuller....?
thanks for the feedback. Does the adjustment adjust the position for both the upper and lower? Or just one?AEV 2.5“ Dual Sport lift on JLUR. Got just above 3“ of lift. I used the middle setting on the castor setting. I did not get an alignment So I’m no help on after measurements. Got about 3000 miles on the lift and it drives great. No issues. If I would have known it was really a 3” lift I may have used the max setting on the shim.
yep. Tracking all that. Trying to determine if people have found the recommended orientation of the shim resulted in “factory“ caster or what has been determined to be “optimal” caster.
The bracket just lowers the attachment points for the upper and lower frame side of the control arms. The upper arm has the castor adjustment. It’s the square metal shim on the upper bolt. The hole is off center in the shim and how you rotate it sets the castor. If you zoom in you can see the notches on the corner of the shims. This position was the mid position. The instructions for the bracket has the instructions for placement of the shims.
Those brackets hang down so low that they wouldn't last a year under my rig. They also impose a huge hang up problem when in reverse.i dont follow.
nah. They arent at all. Theyre barely; if any; lower than the frame side rear lower control arm mount. Rock bashing is dumb anyway.Those brackets hang down so low that they wouldn't last a year under my rig. They also impose a huge hang up problem when in reverse.
Lol, look at the picture. They attach to the frame side bracket and hang a good 2" below them. You don't have to be a rock basher to understand that those are gonna cause problems.nah. They arent at all. Theyre barely; if any; lower than the frame side rear lower control arm mount. Rock bashing is dumb anyway.
Actually. There is something you can help me with.Lol, look at the picture. They attach to the frame side bracket and hang a good 2" below them. You don't have to be a rock basher to understand that those are gonna cause problems.
