Caster adjustment and centering steer wheel
brow
Edmonton, AB
2018 Black JLU
Hi there - not having much luck finding info on adjusting caster and recentering my steering wheel. Can anyone please let me know where I can find this? FYI just did a '75" level with spacer. Thanks!!
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
you cannot adjust caster with the stock control arms as they are fixed and the bolts do not allow adjustability, you can get adjustable control arms from after manufacturers like from clayton, but at .75" lift i would not bother and you will probably not see any issues
for the steering wheel it is pretty easy, get your front tires pointing straight, on the drag link there is a big knurled nut but by the steering box, loosen the nut near it (15 mm i think) and then turn knurled nut until your steering wheel is straight, then tighten the nut
Next Venture Motorsports
