CarPlay disconnects frequently
blightle
Walnut Creek ,CA
2018 Rubicon (JL)
Anyone else notice CarPlay losing its connection. The CarPlay app constantly quit the connection (mainly when I am on a call) but then will generally reconnect itself (but not always).
Jkohler
Jeremy
Utah
2018 jl rubicon 2017 Jeep Grand Cherokee 2017 ram 3500
My CarPlay isn't working with my iPhone 6 at all. It just says not supported when plugged in.
1quick1
Moderator
Staff member
Moderator
2018 JLUS
I had to get a better quality cable as the cheap adapter I was using was causing the same issue. The instructions guide mentioned it will likely only work with the USB cable that came with the phone.
Jkohler
Jeremy
Utah
All have to try the apple cable today. I was using a nicer cable than a factory apple. The problem with mine is the first time it recognize the phone had my crap on the uconnect screen but wouldn't work. I then disconnected it for a retry and got nothing.
JeepCares
Auburn Hills, MI
JL
Hi blightle,
Please send us a direct message with your VIN. We'd be glad to look further into this and if necessary, escalate to a Uconnect Case Specialist.
Jasmine
Jeep Social Care Specialist
tcadaniel
Pittsburgh
2018 JL Rubi
My CarPlay works perfectly. I did not synch my phone to the JL's bluetooth. I found in previous cars that when it's connected to bluetooth and CarPlay, it gets confused. What phone and iOS are you using?
Sloxkhart98
Cumming, GA
2018 Wrangjer JL Rubicon
Mine works great as well. I did get an Anker cable. It could be the iOS. There were some issues with iOS 11x, but since I’ve been running iOS 11.2.5/6 all previous issues have been resolved with my Toyota Entunes. I’ve been on iOS 11.2.5 since I’ve had my Jeep and have not had a single issue.
theplankeye
2018 Rubicon Unlimited
Your cable needs to be replaced or your lighting port cleaned out. I have been using CarPlay for over a year and a half. It happens.
blightle
Walnut Creek ,CA
2018 Rubicon (JL)
  • Thread starter
  • Thread Starter
  • #9
Update: I had a new factory Apple cable still in my iPhone box and started using it. So far, no issues but I have not been on any lengthy calls to see if the problem is fully resolved. Will continue to monitor but maybe it was my cable as someone else in the thread suggested. Thank you
iamronlamb
Ron
So Cal
Jeep Wrangler JL Rubicon 2Door
Hi, did this ever get resolved?
Sloxkhart98
Cumming, GA
It’s happened to me. I just switch USB ports (center console) for a few days. It can also be a bad cable.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
most likely just a connector contact issue, after I spray my usb cables (both ends), and iphone charging port with electrical contact cleaner (non-residue) the problem resolves itself.
Chrysler Factory Warranty
