Cant afford $300-$500 for hardtop headliners? Make it yourself!
Gibbage
Kevin
Seattle area
www.youtube.com
2018 Ocean Blue Sport S
3D Artist
Just finished the first step of a project to make my own hard top headliner, and think it looks great! So far the total cost of materials is about $70 and have really like the results. I have enough materials to do the rear passenger ceiling, but that will need to wait. I did record some footage if people are interested in seeing how to do it. Its not complicated at all! The hardest part was finding a good base material that was light and stiff for wrapping the headliner fabric around.
Video
Crawl Away
Jeremy
DFW
2019 Wrangler Rubicon Unlimited - 1998 TJ Sport
What material did you use?
Gibbage
Gibbage
Kevin
Seattle area
www.youtube.com
3D Artist
Materials used.
1/4" Foamed PVC board ($20)
1 square yard of headliner fabric ($20)
Spray fabric adhesive
sound matting
1/4" staples and staple gun.
Velcro
Was super easy! I will edit the video tomorrow and hope to have it up soon after. Ya. I painted my roof black because I hated the white considering everything in the interior is black. It was distracting and I hated it.
ivo
Johnny
Chicago
2020 Sting Gray JLU
I randomly came across a review of those headliners several weeks ago. I noticed its basic foam insulation boards wrapped in fabric something I could easily replicate. Looking forward to your video.
What paint did you use for the roof?
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Nice work. I may do this when the weather is better. So post as much detail as possible.
Schism75
New England
18’ JLU SAHARA
Looks great! Did you finish the back hardtop piece and if so, did 1 sheet of board cover it?
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
I may do this when I swap tops in the spring. Been thinking about it for awhile. I was thinking about 1/8" MDF as a backer with 1/4" foam board behind it.
I would like to save the templates and let people download them so others can save money. But I am not a tech guy and have no idea how. Prices for headliners are way too expensive.
Shots
Winchell
Ohio
'22 Rubicon
MDF is pretty heavy by volume compared to other materials. You may want to look at lauan (plywood) or even a sheet of HDPE (plastic). HDPE can be bought for about $38 for a 4x4 sheet, 1/8" thick. It's rigid and won't be affected by moisture like MDF or plywood.
If you want something a little more malleable LDPE is more flexible and runs about $2 less. Personally I'd stick with HDPE because the intent is obviously for it to retain the form, not sag or bend.
Shots
Winchell
Ohio
'22 Rubicon
I've got a Sunrider so I won't be doing this on the front panels, but I may do it for the back. Yours turned out really well, great work.
Melny67
Melvin
Staten island
Jeep jlu
I will be following this I thought about doing the same but I like the OEM look how close to it is it?
BrntWS6
Land of the FOID
2019 JLUS, 2002 WS6
Yeah weight was my biggest concern with the MDF, even in 1/8". The HDPE looks promising as a backer and looks easy to cut. I don't really want to use just foam board by itself as it will crease or pop if its bent too much.
I had a hard time finding headliner board that is used in cars which is what hotheads appears to use. Plywood has a habbit of warping so I would try the HDPE first.
Dadgummit
Jon
Anaheim, CA
2018 Rubicon Unlimited -- 1966 Pontiac GTO Convertible
There are several headliner kits for the JL on Ebay that cost about $80.00. Has anyone tried one of those?
