Can The 2018 Sport S Really Overland?
MoWheelsMoProblems
Tez
Idaho
JT Gobi Rubicon
Administrative Assistant
Eddie Oh, WAY A Life youtube channel, got a basic Jeep just to go offroading with. True, it's better with some additions like tires, a lift, and some lockers, but his point was that anyone can go offroad in a base wrangler and still have fun.
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
Right now I own a 2018 JLU Sport S 2.0 which I'm pretty sure it has BLD and LSD. At the moment I rent it out part time on Turo to help make the payments. Other than that should I really start investing money and time into it for an Overland build. I live on an island right now, and i am moving back to mainland soon so i can actually make some dope trips with my wife, been dreaming about overlanding the past few months just wondering if the sport is ready for me to get started or if i should wait and invest into something else.
Depending on what state you plan to land, dope may or may not be illegal, especially depending on the quantities. Might re-think your plan.
Maverick909
Inland Empire
www.instagram.com
you are literally living my dream dude, i think im just overthinking it and way to excited, thanks for your input!!!
I did the same thing in the beginning. I was on the forums reading about people buying 60K rubicons and then pulling the axles and swapping them with 1 ton's. Putting 20-30K into these expensive jeeps for no reason other then resell value. With my thought process even if i where to swap to make a rock crawler and drop that kind of money for the gear it takes to run 40" or bigger tires atleast i didnt spend 60K at the start. take your time and learn what you need when taking trips and then start doing your improvements.
Rubigone
Marvin
Sweden/Morocco
Jeep Wrangler JL Rubicon
I think youā€™re underestimating your Jeep, the wrangler in stock form is still one of the most capable vehicles that rolls of the showroom floor in any trim level. Just make sure you have appropriate tires for the terrain and youā€™ll be all good, no need to spend 20k on it. But of course there is always a difference between needs and wants.
Gunfighter
P.J.
West Michigan
2021 Jeep Wrangler High Altitude
Trying not to get warning points
your right i didnt really think about the plus of starting from a fairly basic model having all the customization options.
I asked a couple Jeep dealers what the most popular Jeep Wrangler models are sold. They all said it was the Sport model simply because most dedicated off-roaders by these because they will install better tires, axles, lockers, suspensions, bumpers, accessories. Buying a Rubicon for them doesn't make sense since they are replacing most components with better systems anyway. The Rubicon is great for those wanting the most "capable" factory Wrangler off the show room floor.
aldo98229
Aldo
Bellingham, WA
Market Research
If you want to add a degree of confidence and comfort to your overlanding, get a $199 pair of swaybar quick disconnects. You will be amazed how much nicer your Jeep drives over ruts and rocks.
This is a fairly easy-to-do mod that works very well, and one that you cannot do to 99% of other vehicles out there.
Enjoy!
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 28E74E7C-89E8-42B6-8CAF-8B06DE0A602B
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 20B20666-14F3-45DC-AE51-7A37CA11D3CB
eveg33
Eric
Pitt
22 Willys
Enjoy!
Iā€™m interested and glad you mentioned thisā€¦can you please elaborate on this? How does this work exactly? Also do you have a link for the product?
aldo98229
Aldo
Bellingham, WA
Market Research
You replace the fixed, bolted-on OE swaybar links with a pair of adjustable units that use tapered stainless pegs and a quick release pin.
When you want to ā€œdisconnect,ā€ you need to get under the front of the Jeep, release the pin on each side, rotate the links 180 degrees, and secure them against the peg at the top of the strut. If the Jeep is parked on a level surface, the entire procedure takes less than 5 minutes.
When you want to reconnect, make sure to stop on a level surface and reverse the operation. Again, it is key that the Jeep is on level surface. It makes all the difference between an easy 5-minute reconnect, or a frustrating half an hour.
I went with JKS Manufacturing; I really like them. But there are other brands out there.
https://www.quadratec.com/p/jks-man...8j8-82geBOKa_6iGHKiecgVmZVGLI30RoCzWwQAvD_BwE
aldo98229
Aldo
Bellingham, WA
Market Research
Hereā€™s a how-to video. Keep in mind they come in different lengths, for Jeeps with stock suspension and for those with a lift.
eveg33
Eric
Pitt
22 Willys
Thatā€™s awesome. Thank you for the info! Will be considering this myself. Great thread by the way OP.
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
Just keep in the back of your mind that the weather conditions might not be perfect when you're wanting to get off of the trail. You'll either have to wait out the hail / thunderstorm / whatever, climb under your Jeep in those conditions, or continue driving really slowly.
I'm having flashbacks to a horrible hail storm / flash flood that hit at the end of a run last summer. People were almost crying as the entire group was trying to get off of the mountain while we watched the trail getting washed away. Driving like that without sway bars?? No thanks.
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
You have the tool you needšŸ‘. Your stock JL is more capable than 99+% of the rigs folks used to use to go everywhere. Believe it or not folks actually used Jeeps to do what is now called ā€œoverlandingā€ for many decades before the first ā€œRubiconā€ rolled off the production linešŸ˜. These were FAR less capable vehicles than what you already have. Get some decent off road rubber (KO2ā€™s or similar) throw your junk in it and go. If youā€™re going alone, throw an entrenching tool, snatch strap and a come along in as well. With those and your spare you can self rescue almost anywhere IF you should get stuck. Iā€™ve been fooling around with this stuff for 50 years. For the last twenty years I run a winch on the front just ā€˜cause Iā€™m old and lazy. Iā€™ve been in a LOT of places most folks wonā€™t ever go, only got hung up a couple time and then was able to extricate myself. I love to hunt and fish way beyond where they pavement end. My Jeeps (And before them, my IH Scouts) have never let me down. I guarantee you your stock rig is far more capable than you are. The most important tool for off road is the one between your ears-if you fail to use that, then youā€™ll need extra ā€œmodsā€ to save you.
eveg33
Eric
Pitt
22 Willys
Didnā€™t have that in mind. Good insight too, thanks John.
GrayWolf.Overland
Subash
Port Moody, BC, Canada
www.instagram.com
2024 4xe Rubicon (Earl Gray)
People overland with Subaru Outbacks with just AT tires slapped on. A wrangler Any Wrangler is an insanely more capable rig and we have had the good fortune of taking it to some of the remotest places in our area reliably.
We dont go rock crawling, and intentionally take the safest line when possible. The idea is to get to the destination and back safely and have fun with the family.
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 1653498546963
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 1653498613378
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 1653498670831
Jeep Wrangler JL Can The 2018 Sport S Really Overland? 1653498693379
