Captain Skip
- Skip
- Oct 13, 2020
- New Hampshire
- 2020 Wrangler JL Sport S
- Occupation
- Happily retired
I'm setting up my JL to tow behind my motorhome. One thing I need to do is add a brake light disconnect system to the JL's brakes. It's a relay that goes inline on the wire on the brake pedal switch and prevents the JL's brakes from overriding the brake light signal from the motorhome. I need to cut the wire downstream of the switch that goes to the brake lights and install the relay in between the cut ends of that wire. Problem is if I read this diagram correctly it looks like there's 3 wires on the brake pedal switch. Obviously I don't want to cut the wrong one. Has anyone else added a brake light relay cutout on their JL for towing purposes and remember which wire you used? Or, can someone interpret this diagram for me? I'm not sure what I'm looking at here....maybe I'm looking at the wrong diagram?
