Yes and no it isnt hardyep I'm a newb who has never owned a jeep. Can someone explain how the dual top works? you take the hard top off
like i nall the videos I see, and then you have to "install" the soft top I assume? Is this hard to do? thks
ok. is this also possible to add in later? or are there special brackets etc involved that would really want it done in factory?Hardtop will be installed along with most of the soft top. The soft top will most likely be mounted to the roll cage and gathered at the back. In order to remove the soft top from the cargo area you will need to remove the hardtop, then either re-install the hardtop or finish the installation of the soft top. For the soft top, you'll need to do some assembly like mount the door frames and rear retainers, but nothing difficult.
This is covered in the owner's manual, page 87-89.
I would say you want the hard top factory so they run the wiring and tubing for wiper/washer.ok. is this also possible to add in later? or are there special brackets etc involved that would really want it done in factory?
I think OP is referring to adding soft top after delivery to hard top only.I would say you want the hard top factory so they run the wiring and tubing for wiper/washer.
If OP is patient there will be complete soft top systems popping up on CL sooner or later just like the JK.I think OP is referring to adding soft top
If that’s the case, OP, check prices. MOPAR/ OEM soft top and door surrounds (rear retainers are part of the body) and soft top frame is muy dinero!
You'll be able to add a complete soft top later. I would figure at least $1,500 for a complete set up whether Mopar or Aftermarket maybe cheaper or find one from a fellow JL owner.ok. is this also possible to add in later? or are there special brackets etc involved that would really want it done in factory?
If your leasing it makes sense to get duel because it minimal in paymentYou'll be able to add a complete soft top later. I would figure at least $1,500 for a complete set up whether Mopar or Aftermarket maybe cheaper or find one from a fellow JL owner.
Remember with the dual top, you get an upgraded Premium soft top for $2,195.
Freedom top is $1,095 so for an additional $1,100 you also get a Premium soft top.
The Dual Top purchase involves you getting a hard top, a premium soft top, and essentially in its pricing model, giving back to FCA the base soft top that comes standard.yep I'm a newb who has never owned a jeep.
Only if you are crazy enough order direct from the dealer (not as a factory option). Mind you I haven't actually looked, but I'm sure Bestop has their soft top options out for the JL, if they don't they will soon.I think OP is referring to adding soft top after delivery to hard top only.
Bingo! In due time there will be new JL owners who got the dual top option and will be offloading the soft top. My wife scored a brand new take off soft top for my first JK off or Craigslist The only thing I had to buy were the 4 screws that attached the actual soft top brackets to the sport bar which I got away with for buck or two at Ace Hardware.If OP is patient there will be complete soft top systems popping up on CL sooner or later just like the JK.
TheOnly if you are crazy enough order direct from the dealer. Mind you I haven't actually looked, but I'm sure Bestop has their soft top options out for the JL, if they don't they will soon.
If I am leasing it’s about 10-15 more per month is it worth getting soft top included in leese
What application is turbo a better options and wheee is v6 betterI think OP is referring to adding soft top after delivery to hard top only.
