Can I see some builds with -18mm offset wheels?
erikthedon
2018 JL Wrangler Sport S 2 Door
trying to get a feel for how much the tires stick out... thanks!!
Stuckinthesand
CJ
NJ
2019 Wrangler sport s 2017 GMC Acadia
35x12.5x17. -18
Black rhino Barstow
JLUS
Bloody Marty
Michigan
JEEP 2 DR WILLYS 21, CHEVY TRAIL BOSS 19
Stuck has good taste. I have the exact same wheels. Here is a straight on pic of -18 offset. Good luck in your shopping
Nice!!
What's that set up then? How wide are the rims 9? & what lift?
I'm thinking of a 2" Mopar lift with 35x12.5x17 9 with that offset
JeepersCreepers2
Northwest Arkansas
2018 JLU Sport S
Nice!!
Thanks much. The wheels are 17x9.5. -18 offset and 4.5 backspacing. Tires are also what u mentioned at 35x12.5.
I’m running a 2.5 inch teraflex lift but the mopar one will net u at least 2.5 inches possibly 3 to my understanding and should remove almost all the rake.
Stuckinthesand
CJ
NJ
Can’t make this up. I’m getting ready to go to the teraflex 2.5” lift. I’m running the RC budget boost right now. What are you running for front sway and how is the rake with the teraflex? I run a steel bumper and a winch so I’m hoping not much rake with it.
JeepersCreepers2
Northwest Arkansas
2018 JLU Sport S
That’s a good looking jeep. I think this is the lift. I didn’t add anything additional. I have a steel bumper so front is slightly lower but u wouldn’t notice unless u measured. I don’t have a winch but can’t imagine u would lose much. As far as ride, I couldn’t be happier with how it drives.
https://www.morris4x4center.com/ter...MIpIeo9equ7wIVhcDACh0ADQmGEAQYAiABEgLr3vD_BwE
Sethward01
Seth
Central Kentucky
2021 Jeep Wrangler 4xe
Thanks for sharing! The setups you all listed are exactly what I want to add to my 4xe Sahara--if it ever gets past the scheduling phase and gets built. Going with the 2" Mopar Lift, 17x9.5 Black Rhino wheels with -18 offset, and Pirelli Scorpion tires in 315/70r17. I was trying to figure out if I needed spacers with that setup, but this post clears that up. Cheers!
Tazer JL - Z Automotive
