Can I fit 35/12.5/17 tires on a 7.5" wide wheel?
Spearmin
Eric
NY
JLU
Got my eye on a set of Cooper Discoverer STT Pros but not sure of the size. I just finished the 2.5 lift so I am being told I can go with 35/12.5/17 on a 7.5 rim. Can anyone confirm this? Not looking to put wheel spacers.
word302
Oregon
JLU
Got my eye on a set of Cooper Discoverer STT Pros but not sure of the size. I just finished the 2.5 lift so I am being told I can go with 35/12.5/17 on a 17.5 rim. Can anyone confirm this? Not looking to put wheel spacers.
17" tire on a 17.5" rim?
word302
Oregon
JLU
You really want to run at least an 8.5" wide rim with 5" at most of backspacing.
Schwabe
Dominic
Maryland
2019 Wrangler Unlimited MOAB
I have the Mopar 2.5 lift and run stock rims with 35x12.5x17 BFG MT without spacers. Only the lightest rub on full lock left, nothing on right lock. So the wheel liners are just not even. Have about 10k miles on this..
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Because your axles aren't centered from your Mopar "budget" lift.
I say "budget" here because Mopar does nothing to address geometry issues as a result of lift.
You might want to invest in an adjustable track bar.
Noah
Mass
2018 Rubicon JL
No spacers = dont do it.
Need 8.5
Schwabe
Dominic
Maryland
What geometry issue? I am running 12.5 on 7.5 stock rims without a spacer or additional offset ... I was not sure if it would work, which is the OPs question. It does work and only has the slightest rub at full lock. No trackbar is going to correct that.
Arterius2
Jerry
Vancouver, BC
Spearmin
Eric
NY
JLU
Then what max tire size can I go with..
word302
Oregon
JLU
His point was it's not your wheel liners that are causing your rubbing on one side. It's the fact that your axle likely isn't centered.
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
technically........most tire manufacturers recommend 295/70 as max width tire for a 7.5" wide rim. 315/70/17 min rim width is 8". 8.5-9 would be better. Many have mounted 315's on stock Rubicon wheels........your choice of course but its not recommended.
I'm surprised so many tire shops will mount them on a rim width narrower than mfr spec.
Watchtower02
Wisconsin
Wrangler
Do you have a picture of those please? I am looking at doing the same thing...
Watchtower02
Wisconsin
Wrangler
What's the harm in putting a 35x12.5R18 on a 7.5" wheel when it calls for 8.5" width wheel at a minimum...sounds like many people are doing this...is this a safety issue or will the tire not wear as properly?
