Shots
I doubt you'll have a huge drop in fuel efficiency. It will go down a bit due to added weight, but that's true of adding any tire that is larger than stock (it won't matter if they're Rubi take off or aftermarket).
Having come from a Ram that got roughly 12 mpg, I'm thrilled with 20+ mpg. One thing you'll notice when swapping to a bigger tire is that they calculated efficiency will decrease, but one thing people forget when they hand calculate is to adjust for the increased circumference of the tire. It's not much, but a larger diameter tire will log less miles. As a result, when you calculate efficiency it shows less efficient than it is because you didn't account for all the miles driven. This is the same issue with the computer's reported efficiency after a tire swap for the same reason. It really is a minor difference, but if you lose 1 mpg, and forget to calculate some miles, that results in .5 mph difference, it makes the loss look worse than it was.
