I’m planning on doing it. You have to disassemble the camera cable to the minimum size, then use a step bit to enlarge the hole Genright puts in them for the wires. Open it up just enough that the new smaller camera wire end will go through and your in business.Ive searched and havent found any info on how to feed the camera wiring thru the tubes, the problem is that the plugs dont fit thru the hole, has anyone installed their camera with the genright tire carrier?
No the factory wiring is long enoughSo you do need new wiring? This is what i thought i had to do enlarge the hole so that the plug fits?
Thanks thats what i thought, but i wanted to ask just to make sure there wasnt another way without enlarging the holesNo the factory wiring is long enough
Just just disassemble the camera wire to the maximum point you can without destroying it. It should be obvious what to do while you’re looking at it. Sorry I don’t have any pics.
Then enlarge the hole so it fits
Not that I’m aware of. Also you’ll need to re route the camera wire out through the upper hinge on the tire carrier for it to be long enough.Thanks thats what i thought, but i wanted to ask just to make sure there wasnt another way without enlarging the holes
Well then you wouldn’t have to drill the hole bigger, just go right to the cameraI was planning to route it through that plug
