camera cover
robertsj22
Justin
Maryland
unlimited sport soon i hope
after putting on new wheels and tires when i go to put the camera cover on it goes on fine but when you turn the screw it doesn't attach to anything. am i missing something obvious or is it just designed to work with stock wheels.
jludave
The Isle of Long
Your new wheels likely have a different offset than the stock wheels and now the spare is sitting a bit further from the carrier, causing the camera cover to not go back on fully. If you have no choice you can run without the cover or see if you can figure out if you can modify it to fit.
FLjeeper
Jason
Melbourne, Florida
2021 Jeep Rubicon JLU
Mine just didn't go back on. I thought about possibly looking into finding a longer bolt solution but honestly it doesn't look bad enough to really care about so I left it.
robertsj22
Justin
Maryland
yea its like i need a lug nut thats 4 inches long to get it to attach to something. What is that lip that slides out supposed to go behind?
VooDoo1
Don
Sacramento, CA
2018 JL Sport S, 2007 FJ Cruiser
The JL's have 2 different camera covers. One is for the Sport with steel wheels and the other is for the Sport S, Sahara, & Rubicon with aluminum wheels. The cover for the steel wheels is longer and will not fit with aluminum wheels. If you started with a Sport with steel wheels and put aluminum wheels (after market or OEM) you will need the shorter camera cover.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I was lucky and mine fit after I went to new wheels even with the negative offset
D&C Designs
