AnnDee4444
AnnDee4444
'18 JLR 2.0
AnnDee. Thanks. When I downloaded the spreadsheet into XLSX per the instructions, it kept the tables but lost the graphs. Do you have a suggestion for capturing a download with the cool graphs?
It looks like there's something I've done with the graphs that prevents Excel from opening them correctly. These were created in Google Sheets in order for them to be easily sharable, and I guess this is one of the downsides.
I don't have a solution for this yet, but I can suggest keeping it all in Google Sheets and copying it to your personal Google account, like this:
Jeep Wrangler JL Calculator: gear ratio, tire size, speed, etc. Untitled
pnut
M
Michigan
2022 Wrangler 392 XR
Any idea if this is valid for the forthcoming 392? Meaning the trans is the same as the auto one listed? Thx.
AnnDee4444
AnnDee4444
'18 JLR 2.0
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
Here's a spreadsheet I built to calculate gear ratio, tire size, speed, etc. The yellow colored cells are how to control the inputs (either drop-down or number fillable), all other cells are un-editable.
bt39.com/GearWheelSpeed might be easier to use.
If you are having trouble using the spreadsheet because another user is currently editing it, you can download your own local copy in Excel format:
I use session ID so everyone has their own data and there are no collisions. I can add anything you like to be displayed by default, although with the edit link you can change any parameter.
I plan to add graphs, that's pretty useful.
The_Skyo
Vancouver, BC
2022 JLUR 6 spd 4.88
This chart is fantastic despite there not being many comments here. For me it raises some questions though.
I currently drive a Focus ST (manual) with a 2L turbo inline 4. I can shift into 6th on flat ground at about 80kph (50mph).
I recently ordered a manual rubicon with 4.10 gear ratio. With the option of 4.88s giving nice crawl ratios I'm a little torn by what I see in this chart.
At 50mph with 4.10 (33" tires likely staying so it fits in my garage with a roof tent) I'd be at 1500rpm. With the 3.6 not being so torquey at low RPM since it has no turbo it sounds like people try to stay above 2000rpm. 4.88s would bring me up to 1789rpm at 50mph and 2147rpm at 60mph which sounds useable.
Does it really kill my MPG if I got 4.88 on stock 33" tires? I don't often go above 75mph around here and people have complained that the gears are too tall and they sound much taller than the Focus I drive so 4.88 actually sounds like it's closer to what I'm used to. Any first hand experience with both here?
damageinc321
Indiana
2018 wrangler rubicon unlimited
I recently had a forum member question why a manual with 37s & 5.13s is actually 70 MPH @ 2500 RPM while this calculator shows 75 MPH@ 2500 RPM. Here are some tips:
  1. This calculator is using the numbers for a true tire size. The number you enter is what the calculator will run. Many tires are actually less tall than the advertised size, sometimes up-to an inch shorter. Also, all tires sag when loaded, which I think could also have an effect.
  2. A "5.13" gearset has 8 pinion teeth & 41 ring gear teeth. This actually calculates to a true ratio of 5.125:1 (41 / 8 = 5.125). This hardly makes a difference, but is worth noting. I'm also not even really certain what the quoted "0.72:1" 6th gear ratio actually is.
  3. Even after speedometer correction, inaccuracies are more apparent at higher speeds.
Other than that, the rest is math. I'm rounding to the nearest hundredth below, but the calculator is doing the true calculations. Here's how it works:
A true 37" tall tire without sag will travel 116.24 inches per revolution (pi*diameter)
which is also 9.69 feet per revolution (116.24 / 12)
and finally 545.08 revolutions per mile (5280 / 9.69)
To calculate the overall ratio, multiply the axle ratio by the 6th gear ratio: 5.125 x 0.72 = 3.69 overall ratio
At 2500 RPM, the axle & tire will turn 677.51 revolutions per minute (2500 / 3.69)
The tire's 677.51 RPM @ 545.08 revolutions per mile (from above) is 1.24 miles per minute (677.51 / 545.08)
Which is also equal to 74.58 MPH (1.24294 x 60)​
I have 37s 3.6 auto with 5.13 gears and I'm using tazer for recalibration. I used actual tire size and 5.13 for gear ratio but my speedo is off by 1 mph , should i enter 5.125 ? Would that fix it?
word302
Oregon
JLU
Don’t adjust your gear ratio, adjust your tire size.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
The more accurate your inputs the more accurate your results will be.
Adjusting your gear ratios to be more exact will have a minor effect. If you're really OCD about digits of precision go ahead and put the numbers in. But adding digits of precision like that won't make big changes in the results.
The biggest thing that affects your results is getting an accurate tire size. Getting the true rolling diameter of a tire is difficult. It's affected by inflation pressure, weight on the tire, even tread wear. And then you have to deal with how the air pressure in your tires varies as you drive and the tire heats up.
Tires can be more than an inch off from the advertised size and that's a huge impact. I had some 35s (315/70R17) that had an advertised diameter of 34.4" but an actual rolling diameter of 33.5". Getting the tire size accurate made the calculations pretty close but only within a margin of error.
Then there's the other side of it. Even if you have accurate inputs in the calculator you're dealing with a vehicle that has factory spec gauges. They are only "close" to what is actually going on. Your tach can be off, your speedometer can be off. So you can't know for sure what's going on. Hell, the speedometer needle in my Jeep is 1-2 MPH off from the digital display. And they're both running off the same signal.
Honestly, the best way to use charts and calculators is as a rough estimate. They will tell you a good ballpark number but they will never be 100% precise compared to what you see in the real world. Rounding ratios to 2 decimal digits is well within the variance of the gauges in your Jeep.
If you obsess over 6 digits of precision in this environment you're just going to frustrare yourself.
And when it comes to programming your Jeep, use the 5.13. Tweak the tire size to make the speedometer accurate.
AnnDee4444
AnnDee4444
'18 JLR 2.0
Somewhat related but not that useful... calculated tire diameter vs. rolling tire diameter
Also not that useful... if you want to calculate the exact gear ratio: ring teeth / pinion teeth. A "5.13" for example is 41 / 8 = 5.12500000000000000....
Two decimal points
Jeep Wrangler JL Calculator: gear ratio, tire size, speed, etc. Gear.PNG
Four decimal points
Jeep Wrangler JL Calculator: gear ratio, tire size, speed, etc. Gear 2.PNG
MCJA
Matthew
Olympia, WA
2020 Wrangler Unlimited Rubicon EcoDiesel
Going uphill in 7th gear in a rainstorm on the third Thursday of the month, my speedometer is off by 0.28713 MPH. My vehicle is loaded with myself, my wife, a dog, a parakeet, 2 bags of groceries and a tuba. What equation should I use to calculate the distance between the Earth and the Moon? I need 8 significant digits. No less.
AnnDee4444
AnnDee4444
'18 JLR 2.0
The moisture from the rainstorm likely caused your wheel-speed sensors to read incorrectly. Since the parakeet's wings aren't very big, use the tuba to blow the sensors dry. Have your wife watch the dog to make sure he/she/they don't eat your groceries or the parakeet.
Oh, and use this formula: https://en.wikipedia.org/wiki/On_the_Sizes_and_Distances_(Aristarchus)#Half_Moon
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
Baldo72
Luca
USA Charlotte NC
2022 JL Rubicon, Alfa Romeo Giulia, 1972 JEEP CJ5
Got my Rubicon XR yesterday at Gupton...as it was swimmy to begin with and funky to drive with the XR package on prior to the tires to set in...I was wondering if you have any suggestions on what is the best PSI for On-Road and Off-Road for the XR factory tires? new to the Wrangler world and looking for some help. These 35's came inflated at 50PSI when i picked up yesterday...
cheers!!!
word302
Oregon
JLU
cheers!!!
I’d start with 30PSI and chalk them.
