Adamoni
I read up on CAI here and want to know if I got this straight. Please, correct me if I’m wrong because the Mopar CAI just became available to order as a stock option. I may add it to my diesel order.
1) HP and Tq gains?
An external intake, like Mopar CAI, should help keep hp and tq stable more than noticeable gains.
2) Sound
Expect a change here. Open cone under hood CAI will be loudest. External intake from the side, like Mopar CAI, will be less. Snorkel will be least.
3) water intrusion
Stock or under hood best against rain and washing. If external intake, it would be nice to be able to close it off. Kind of like I’m seeing with the Mopar CAI (there’s a flap). If water fording, you should have a snorkel. Stock might be next best. Side hood external intake might be worst because a rogue wave has open access.
4) Dust intrusion
Put in the proper filter for your environment
In addition to commenting and correcting the above...
5) Please answer this question for me: does the JL ‘reprogram’ itself for this added air flow intake? (Because when I put a velocity big air kit on my motorcycle I had to get a power commander fuel controller and basically a Dyno tune to get the correct map so it ran right afterwards)
6) Diesel
Any concerns here about adding a CAI to the diesel? Also, Do you think the expectation is that Mopar will run an external snorkel from there side opening external kit that we now can have installed as a stock option on the diesel?
1) HP and Tq gains?
2) Sound
3) water intrusion
4) Dust intrusion
6) Diesel
