Shellbird01
- Bob
- Apr 8, 2018
- Ontario Canada
- 2018 Wrangler JL Shara Unlimited
Wow amazing $$$
Hey Dave - did you have to trim/notch the portion of the truss under the coil spring perches?Got my front axle trussed with the Artec armor kit, RCV's installed in the front axle, a Metalcloak front differential cover and skid plate installed, and Teraflex 1" spacers added to the rear to level out the Jeep.
Thanks! I'm not sure about the truss. I didn't put it on, as welding is not a skill of mine (yet).Hey Dave - did you have to trim/notch the portion of the truss under the coil spring perches?
I'm gearing up to do my truss soon and by eyeballing it, seems like there might not be enough room for the bump stop extension nut under the coil spring perch with the truss in there. I don't have the lift/extended bump stops yet, so I can't tell by tossing the truss in there on mine.
One more - did you have any trouble with the rock sliders trying to occupy the same holes/realestate on the frame rails as the Rusty's skid plates? I have the LOD Signature sliders as well and have been considering just an engine skid because I can't confirm the sliders will play nice with a full belly system.
The Jeep looks killer!!! Great job!
That's really helpful. Much appreciated!Thanks! I'm not sure about the truss. I didn't put it on, as welding is not a skill of mine (yet).
As for the skid plates, there is one mount on each side (near the rear) that shares a bolt. In the picture, it's the bolt with the armored washer. It doesn't seem to affect how the sliders fit though.
Interesting the differences you found in build quality between the two brands. What about modding the ends of the Warn to make it meld better? Seems like it would be the best of both worlds.Installed a Road Armor rear bumper to replace my Warn Elite bumper. I don't like it as much as the Warn, as Warn's bumper's brackets and structure is much more stout. But the Warn stuck out further than my new Road Armor fenders, so it looked odd. The license plate bracket was also much more sturdy on the Warn than the Road Armor.
I also installed Rigid Industries SR-M Pro difussed backup lights, which was multi-hour project due to the bumper design. More details on that on this thread: https://www.jlwranglerforums.com/forum/threads/road-armor-rear-bumper-lights-warning.62320/
I wish, but I'm not sure how to do that. I would somehow need to trim about three inches of width of each side. As it turned out, selling my old bumper offset much of the cost of the new one.Interesting the differences you found in build quality between the two brands. What about modding the ends of the Warn to make it meld better? Seems like it would be the best of both worlds.
-Steven
I wheel trails that are rated up to 6-7, and they have taken hits on both sides now. They use the exact same mounting points and hardware as the signature series, but they stick out probably 4 inches wider and 3 inches lower at the widest point than the signature series. The signature series angle up as they get wider. Because of all of that, I seem to be hitting them more often. They haven’t moved from the hits though.Nice build! Question on the Destroyers. What kind of wheeling do you do? And what kind of impact did they take? I’m on the fence potentially for the same rails, but I’m having a hard time figuring out how weak/strong they actually are.
