NoPoMoCo
Been doing a lot of research and reading a lot of product reviews and I just can’t seem to find the right Cab Cover.
Here are my requirements and constraints:
the situations is ability to stay topless as much of summer as possible and not have to put soft top fully back on for when a day or two of rain is predicted. It’s mostly under cover but exposed to possible sideways rain and a lot of humidity based moisture (near ocean). Also for theft of property. I do lock the arm rest but want to have it less attractive to search through with the cover on
JLU
Want Black
Water proof although water resistant is ok if it does like a 80% repel-meaning dripping ok but puddle on seats not acceptable
Ability to cover retracted or closed Bestop TrekTop NX fastback ( obviously windows removed)
Obviously doors will be off
I have no accessories that hamper the cover (I.e light bars )
I don’t want the ones the fit around the stock side view mirrors because I’m using the hood hinge mounted mirrors
I don’t need the ones with ‘door’ access because want...
Lockable -meaning has grommets that I can run a cable through
i see most of the ones in the range cost $175-200. I’m willing to go higher for the perfect solution (if that even exists)
JLU
Want Black
