TCogs1
The more recent mod's I've completed in the past couple weeks apart from the CMM mirrors and some tube Doors from Jeep Beach were to flip the sway bar motor to get some more clearance as well as getting the EVO-kit Specific Inner liners from AAL. The CMM kit was super easy. Just pop out the upper bolt cover, slap some blue loctite on there and screw it in. Very nice CNC work.
The plan was to get some tube doors. I bought a set at Jeep Beach for what I thought was a good deal but it was Meh at best. Free TJ mirrors included which I'll never use with them lol.
Tube doors are SOLID. Really hoping they release the Mesh they had on the Orange one at the event... I actually have not looked lately so may call on that tomorrow.
The motor flip was just a single bolt from Metalcloak if my memory serves correct. I purchased it from a member on this forum. Pictures don't show exactly how well it gets up and out of the way.
Before:
After: (night Pic on phone so enjoy this super duper high resolution artistry)
Lastly, this is my most recent addition and one I've been anxiously awaiting for quite some time to protect all those electrical bits on the firewall. I originally purchase Artec Inner liners with the thought that I would just chop them up to fit my coil overs. Yeahhhh, that plan was going to fail for sure so I decided against it and was going to go back to oem plastic set that I would cut for now and fab my own eventually. About that time, Brit from AAL emailed me saying he was going to produce a set of liners nobody was making... After some peer pressure to tell me and some groaning of my issue, he mentioned a quick turn set, one with a panel specific for EVO. As a motorcycle guy who loves 1.4 turn dzus for tearing down bikes quick, it definitely had my attention. They arrived last week and I just installed them a couple days ago. 100% easiest install I've ever done on any vehicle. I mean seriously, every liner should be made like this, it was freaking awesome. Took not even an hour of me working at super snail pace while checking my Tinde... I mean Emails.
The tires rub the liner at full lock. I am going to pull out the back section, toss it on the brake and bend it back into the body towards the bottom. Might stretch the front a little as I need to replace the driveshaft anyways and that should alleviate most of my issues. That's pretty much where I stand right now. I'll grab some pictures tomorrow of my accidental DIY clearanced corners via the flex/crunch method with 40's... oops. I plan to throw on the Jtop Sunshade when I get a break from the rain which is a no-go right now.
Most intriguing things on my list right now are the Bestop Sunrider, removing rear muffler and doing something in the middle of the body to clean up the rear end while keeping it silent, better spread reverse light(s), trailer plug solution, drilling bumper to add back up sensors again.
I am really hoping I can come up with a solid system for fitting my winch plate/winch in this bumper without cutting the grill to clearance it. It's too tight of a fit currently but I really don't like how far most JL bumpers stick out from the body so I WILL make this bumper work. Who else will be running a JK AEV Stubby on their JL? Hope everybody reading this has enjoyed the pictures so far. Feel free to ask any questions and I will post up more soon! Going to Hardrock Asap, Jasper Jeep fest for labor day weekend in ATL, then Windrock in Oct.
Hey Brother Mojito!
Thanks for all the mod pics... after running Rubicon and Coyote trails.. I really need to get serious about rear inner fendors...
Did you do yours yet?
Mine rub at full flex, even with adding 2000LBS Airsprings… (not a bad)..
Thoughts..?
Thanks..
TC
Lift height is 2" mopar, everything else is stockAre you rubbing in the same area as my jeep that the pictures show or is it somewhere else? What Lift height are your running? Unless it's a lower height build, with 37's, I'm surprised your having issues as my buddy is running them on 3.5 inch lift and it clears perfectly fine in the rear. I am not familiar with running the airsprings assuming it is similar to pressurized airbags within the coils to reduce or slow compression? The main issue if I am not mistaken would be correcting your bump stops to limit travel to the point of touching the body.
Correct me if I was wrong in interpreting your issue!
Rub is real light in the front (bumper and top of fender liner), which I am not worried about.
Rub in the rear, is more significant thus my query about rear liners.. thanks for the pictures and mfg name.
Airspring (air bag), really helped push the weight forward and minimized the rubbing in the back.. but its still there even with 2000LB more spring rate (via air bag @ 50PSI = another 1.5" lift fully loaded)
"The main issue if I am not mistaken would be correcting your bump stops to limit travel to the point of touching the body."
Your probably right, but this is my last choice, as it would limit travel and I am hoping to run the same inner fender you did and hopefully gain some room that way...
Thanks again!
TC
