Burger JB4 tuning available now
drburns
New Jersey
2020 Jeep Wrangler Rubicon
One thing to add about the DV+ spring as a potential issue is there are some guys running it with the spring and JB4 w/o any issues, and a couple using stock bov with the same issues I have.
AnnDee4444
ā€Ž
'18 JLR 2.0
Be careful when back the hardware out... the aluminum on the mishimoto inter cooler pipe is really soft! After 3-4 installs of stock vs dv+ with/without piston I stripped out one of the threads.
wound up re tapping and adding steel threads back in on all 3
I haven't looked at these in person so this might be a stupid question, but does it look like it's possible to install threaded studs instead of bolts?
drburns
New Jersey
I donā€™t see why not. I think the depth is almost 1/2ā€.
Rub-ISH
Las Vegas
18 JLUR 2.0t, 22 Volvo XC60 T8 ER, 06 Audi A3
I figure yes... I just went the other way because of the hardware I had on hand.
The only trick of doing it with studs would be the length required. The pipe is actually two pieces... one is the main pipe and the other is piece for the recirculation port back to the turbo
drburns
New Jersey
So I pulled the spring out of the DV+ and only got one hesitation on map 2. The Jeep also felt a little more sluggish but Iā€™m not sure if that was from the spring being removed or from the hot, humid weather (more likely).
Josht10
Josh
Amarillo, TX
2019 Jeep rubicon unlimited
Would I be able to use a OBD2 splitter so I can add this and keep my Tazer? Any issue with functionality?
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Yes, you can use a splitter, I do so with an "Automatic" OBD module to send locations, etc.
Or if don't own a Taser yet the Mini/Lite use the secure gateway plug and not an interference.
Warpath
St. Louis
2019 Wrangler 2.0T JLR 2-Door, 2020 GT500
Hesitation and complete power loss can be a boost leak.
drburns
New Jersey
It only occurs from a standing start with full throttle on the 1-2 shift, sometimes 2-3 shift. Otherwise it runs fine. If I roll into the throttle itā€™s fine, even on map 2. Iā€™m not sure if the Jeep is like other cars where the tune is torque limit based and itā€™s hitting that limit too fast, or what.
Warpath
St. Louis
I had a Mitsubishi evo IX. I remember I would have intermittent hesitation when given full or part throttle. Till one day the intercooler hose blew off a coupling because it wasn't tight enough from the factory. The pressure from boost builds the hoses expand and the leak which wouldn't normally show itself will.
drburns
New Jersey
Interesting. Easy enough to check for it, although all the log files show itā€™s making and holding full boost.
Warpath
St. Louis
I hope it helps!
stevieb92
Pittsburgh, PA
2020 JLU Rubicon 2.0t
Mechanical Engineer
I'm seriously considering purchasing the JB4 tuner. Is this the best option out on the market right now? I've checked out a bunch of results with other makes and models (as well as the Jeep 2.0t) and am impressed. Thoughts?
