ChattVol
@Krondor @Sean K. @Flip888I sorta disagree here. Lunchbox lockers have their place. They have their quirks and drawbacks too.....the big advantage is the price. The bigger your tire, the less likely you'll be to notice them. That said, they have a pretty high (IMO) failure rate....25% eventually fail (according to the SW US regional PowerTrax sales rep back in the day). That's mostly due to wear patterns in the factory carrier that houses the much harder Zytel locker parts you replace your spider gears with. Even with thrust washers....you get oscillation that can eventually wear through the carrier and cause a failure. If you install in a new carrier....they are actually very reliable.
But who would do that when you have to buy a factory new carrier AND set up gears on it?
Well, compared to a full Detroit Softlocker with its known problematic dog clutches wherein when an axle blows it, very efficiently, transfers all torque to the opposing axle....transferring the power through the Detroit and dog clutches that then explode and sometimes even break the other axle. Comparatively, the LockRight (as an example) doesn't have the dog clutch problem. You break an axle....and it's just the axle that's broken, not the locker too. So in some cases, it may make sense to go with the "cheaper" alternative.
Selectables like ARB, Zip and Eaton Electric have their own +/-.
I'm starting locker research. What are your thoughts on something like this when it comes out for the new jlus d30 and d35 axles? Thanks again!
