zeebo56
- Zee
- Mar 8, 2020
- los angeles
- 2020 jeep wrangler unlimited sport
- Vehicle Showcase
- 1
Awesome. Thanks for the info and the help. I think the plate has been working out ok for me since I extended the stops to add support and my wheels are 22lbs along with the lighter milestar 37s vs other setups.All good dude I thought you still had the RC plate but no sweat. Having to buy a new plate is a small setback, a lot of people are steered into these way more expensive aftermarket contraptions but that's another topic, so maybe you dodged a bullet.
Also, depending on your wheels and exact size of your tires, you might not even need a plate with the rubi carrier. You 100% do if you use the stock wheels because the spare is so close to the gate, and the bumper sort of tapers in. But with aftermarket wheels with a ~4.5"ish backspace you can sometimes get away with it. Here is an example.
Now as far as the rubi carrier install goes I have one tip that might save you a headache. In my case, the backup camera mount on my stock carrier was not just held in by the 2 hex bolts by the wheel studs. It was also held in by some adhesive in 2 or 3 spots. So I got underneath those spots from the inside with a big flathead and a hammer to break them free. Hopefully yours will drop out just by removing those 2 bolts but if not, now you know what you have to do.
I'll post back and let you know.
I realized the poison spyder bumper I have also sits higher than other bumpers which is why the RC place alone wasn't working for me. My buddy has the RC plate and a different bumper and I think 37s would work with his setup.
