Broken Bolt while Installing LOD Destroyer
FL Mojito
Tampa, FL
2018 JLU Sport S
When installing the LOD Destroyer sliders, I broke one of the bolts. In the center and rear of the jeep next to body bolts, there are two smaller bolts. Made a stupid mistake while installing and snapped one of these bolts. It is the two bolts labled A in the diagram. Any idea how to fix or replace these? Any suggestions? Thanks!
IPvFletch
Kevin
ATX
JLUSS
How did you break them? You said re-installing? Did you cross-thread it, or did you not clean out like loctite or whatever was in the threads maybe? Learning how you broke it (got it so stuck) would help determine the best course of action for removal. For instance, if it is cross-threaded, or really truly stuck in there, taking it out with a reverse drill bit likely won't work. It won't be durable enough to unscrew it.
You may end up needing to drill it out. Start small and increase size until it caves in and falls out. It will end up needing a drill bit almost as large as the main shaft of the bolt to get it to come out this way.
Only other idea I have is find a welder and weld a nut or something else onto it - give it a new bolt head, and then unbolt it. The welds need to be good for this to work, depending on how stuck it is, though.
FL Mojito
Tampa, FL
2018 JLU Sport S
I over torqued the nut and snapped the bolt. Was installing with impact gun and had on the wrong setting and snapped it while tightening. It was dumb and just working fast and not paying attention. I was thinking about drilling it out and getting a new bolt/nut and some washers. It seems the bolt is a stud and welded in place.
Two options are drilling out or taking to dealer/bodyshop to replace mount.
IPvFletch
Kevin
ATX
JLUSS
If it was fully bolted in, and you just overtightened it, and broke off the head, then you probably could re-weld a new head on and really it's no big deal. The threading should be in tact still.
XJrider
North East
Rubicon JL , 2 JK’s , XJ
Post a photo, its hard to tell you how to approach without seeing the status of that bolt.
rustyshakelford
Rock Sponsor (Level 1)
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
From the pic he snapped off the nut with the threads. The head will be more than likely tacked above the body mount assembly. You need to do some digging and see what it would take to get above that or if removing the troublesome big bolt and other nut will allow it to drop down.
Brett
IPvFletch
Kevin
ATX
JLUSS
Ohhh, yeah, the bolt looks like it's tacked/welded in place, and I see, the nut comes off. I didn't have to touch those on mine (JCR) but now I see what you mean.. bummer..
FL Mojito
Tampa, FL
2018 JLU Sport S
Here are the pics. It is a stud, tacked in place. I do not think the existing piece is fixable, so either go to dealer to replace or drill out at try and fix it with a nut and bolt from hardware store.
rustyshakelford
Brett
Navasota, TX
Can you access the top of it? If you can see if you can knock it out with a punch and replace with a bolt and nut up top
Brett
FL Mojito
Tampa, FL
2018 JLU Sport S
I can access the top. Not a ton of room. I thought about trying to punch it out, but it seems on there pretty good. May try to punch it first if that doesn't work then drill it out. Off to find a replacement nut and bolt.
lodoffroad
Indiana
2018 White JLU
That's a bummer! I'd probably just drill it out like everyone else had suggested. If it's any consolation we've been running for almost a year with one missing nut:blush:. Maybe just wait and see if it causes any squeaking or other issues?
-Michael
mike_b_81
Iowa
2019 JLUR
Or, if you have a hacksaw, you can just use the blade with something wrapped around the blade to hold on to, cut off the tack welded stud and bolt it back on. Just using the blade would be the equivalent of using a flush cut saw, the blade will bend pretty good, like I said, just wrap something around the blade to hold on to.
Exact Center
