Broken Body Bolt on 2 Door
ConqSoft
Keith
Wake Forest, NC
2020 JL 2 Door Rubicon 6 Speed
Systems Analyst
So it happened to me. Front driver side snapped. FML.
Jeep Wrangler JL Broken Body Bolt on 2 Door 1D8F23A2-8118-445B-B18F-F2533F815D71
Jeep Wrangler JL Broken Body Bolt on 2 Door A2DD1695-7971-4849-BA1B-04D30AD9B00E
Rhinebeck01
Multiple places..
@ConqSoft ft Yes, it is safe to drive to the stealership with one broken... Just go easy, driving there.. This is assuming the other body bolts are tight. No, I am not just guessing or speculating on this. 8-)
Rhinebeck01
Multiple places..
@ConqSoft
IF you dealership parts department has trouble figuring out what body bolts you need..... they often have trouble figuring it out as the parts listing on their computer in regard to the body bolts is not clear... Anyway, below are the part numbers for the 2 dr. JL. Some guys use new bolts when they remove those bolts on their new JL as they are afraid the bolts have been stressed at the factory or get stressed when you forcefully remove them.
2 dr. body bolts:
Quantity 2 - Mopar part# 6511826AA $3.85 each
Quantity 2 - Mopar part# 6508326AA $19.83 each - ouch!
Stetson
Salt Lake City
2018 JL Rubicon, 2014 Ford Raptor
Project Manager
I did the same thing trying to install step bars on my jeep. Instead of going to the dealership I took it to a body shop and let them fix it for me. They took out the old broken bolt, put in a new one and finished the installation of my step bars. I think it cost me around $250 or so.
As far as driving it goes, a drive to get it fixed should be fine. I wouldnt do much more than that.
Stetson
ConqSoft
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Thanks for the reply!
I’m going to see what the dealer says. I’ve done a lot of research on the methods to correct it, but I want to give them first shot at giving me an estimate to repair it since it’s only a few weeks old.
ConqSoft
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Dealer is able to do it tomorrow so I’m taking it in first thing. Quoted me $280 which includes two hours of labor.
Rhinebeck01
Multiple places..
@ConqSoft
I strongly encourage you to have dealer do your add on install while they are at it. Another hour of labor to them may save you $ in the long run....will save you angst also.
ConqSoft
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
I decided against it. Getting money back and not going to bother with anything that uses the body bolts. :)
Rhinebeck01
Multiple places..
To me, that makes little sense at this point. Oh well....
Myron
Myron
Mitten State
2020 Wrangler, 1964 Land Rover SIIA 88
Newbie, so still learning all the different Jeep Things. Could someone tell me which bolts have this tendency? I have a 2020 2-door on order that should be here any day.
Thanks,
Myron
ConqSoft
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Thanks,
Myron
It’s s all the body mount bolts on the 2 and 4 door models. 99% of people have no reason to touch them. There are a few step/slider options that require you loosen these bolts though.
Myron
Myron
Mitten State
Got it. Thanks ConqSoft.
Rhinebeck01
Multiple places..
Thanks,
Myron
@Myron On the 2 door it seems the front drivers side is what you hear has been broke. Could be cause most guys start there. Most dealers will charge you 2 hours labor to do the install. For that couple of hundred $ alot of guys would let dealer do it. If they break a bolt they eat cost of fix, not you. Anyway, fronts are the ones that break more often.
ConqSoft
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Sliders: $428
Repair: $300
Dealer Install: Another $300
So I can shell out $1100 or cut my losses, keep the steps I have, and only be out $300.
Rhinebeck01
Multiple places..
@ConqSoft You will be paying return shipping on that add on. Seller may charge you a restocking fee. Shipping back will be expensive. Might be cheaper to throw the hour dealer labor at it. AND, you did like/want them..
