AnnDee4444
I remember reading that the JT has different rear brakes. Can't seem to find any links right now, but it could be a potential upgrade for the rear.
Can confirm, Willys have "AntiāLock 4āWheel Disc HeavyāDuty Brakes" as part of the Willys Package. They work great for me, especially with the diesel.Yes, all Rubicon's have the "big" brakes, as well as the Sahara's. Not sure, but I think the Willy's might have the big brakes too.
Initial bite is better, thatās likely due to the better pad composition. Pedal pressure is the same for me, firm yet progressive response. I havenāt noticed too much brake dust, but the Jeep isnāt my daily anymore. There isnāt any noise. Biggest suggestion I can make to anyone doing any brake changes, you HAVE to bed in the brakes properly. Each manufacturer has their specific procedures, follow those procedures as close as you can.Thanks for the feedback on the Powerstop rotors and pads. Can you elaborate some on the improvement?
What I'm looking for specifically is:
Initial bite - is it stronger than stock?
Is there more pedal pressure than stock?
Does there seem to be more clamping pressure with the new pads and rotors?
I'm not too concerned with how much brake dust they emit, but are they quiet?
Thank you
Thank you, that's great feedback.Initial bite is better, thatās likely due to the better pad composition. Pedal pressure is the same for me, firm yet progressive response. I havenāt noticed too much brake dust, but the Jeep isnāt my daily anymore. There isnāt any noise. Biggest suggestion I can make to anyone doing any brake changes, you HAVE to bed in the brakes properly. Each manufacturer has their specific procedures, follow those procedures as close as you can.
Guy, I wouldn't worry about getting new rotors, but those Z36 pads for sure! Unless your rotors were heat warped, deeply scored (below the minimum thickness spec), or otherwise damaged they won't make a significant difference.Thank you, that's great feedback.
I also completely agree on bedding the brakes in, very important!
