BlackGenesis
- Andrey
- Dec 4, 2019
- Muskegon Michigan.
- 18 Sahara unlimited
After numerous fours of looking up and comparing specs, I desided to pull a trigger on something that I know will last - Braille battery, for my AUX replacement.
This particular battery (part#B14115) is exactly the same size as OEM, however packs more juice. Its 15Ah vs 12Ah and has 360CCA vs 200 CCA. Came tested from factory at 483 Crank Amps.
Instead of using provided bolts to secure battery leads, I opted to reuse OEM battery studs. Used 4mm socket to unscrew studs from OEM and put them on Braille.
Bought this from tirerack as they were the lowest price and also included battery mount (which I will use on my sport scar, use 17lb baille to run and start it) $186 after tax, free shipping, arrived in 1 day.
Sorry...no pictures of a box (actually came in box in a box)
